Help im stuck
sounds like maybe the fuel pump is on its way out, get a fuel pressure gauge and see what its reading. beforehand, you can check spark
if you give it a bit of throttle does it keep running?
What I did was uninstall the old fuel pump and plug in just the positive n negative on the new pump, turn the key and it turn on. It took 10 minutes to do. But man that put look original from factory. I'm buying a used one for $20 for now. Cuz I'm getting a upgrade fuel pump for my turbo setup I'm working on now.
I don't believe OEM ones are the same. Aftermarket might be the same for all third gens though, not sure.
You know you can always look up answers to these types of questions up right? Go to one of the online Nissan parts places (nissanpartszone.com, Courtesy, etc) and look up whichever part for both VG and VE, if it's the same part number it's the same part..
Huh?
Right now I'm looking for either a good standalone or a piggy back to tune the motor. And researching for upgrade injectors. I've got everything else. I have a shop making a custom turbo manifold for me when I'm ready to install everything.
Nistune way to go for tuning. You have vg or ve? Ill be selling my manifolds this winter when I make another setup. Also I have some 370cc injectors for sale.
ummm no...the Apexi SAFC is NOT a standalone it's barely considered a piggy back. NOTHING...and i mean NOTHING is a plug and play for the 3rd gens...haven't you learned that by now???
I look it up and it looks like nistune type 3 is the only chip made for ve30de. Correct me if I'm wrong.
It's sort of a plug n play , you really don't have to wiring up the motor at all.
check Nistunes website to see which you need, last time i checked was a few years ago but i think VG30E are type 2
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
even if it is the same as a VE fuel pump, VG will be way more common than VE
