Automatic Windows
Old Sep 7, 2013 | 05:47 PM
MtWalt's Avatar
Automatic Windows
I have a 1991 Maxima and the drivers side window will not roll up. Any suggestions? If I can just get it to go up and stay up I am fine with that for a while.
Old Sep 7, 2013 | 07:41 PM
Hectic's Avatar
Type "window regulator" into the search bar, you'll find thousands of results.
Old Sep 8, 2013 | 09:46 AM
shiloh51933's Avatar
Take inner door panel off and you can pull window up manually. Could possibly be the motor or could be the regulator. If a cable snapped on the regulator then the window might not stay in closed(up) position, you'd have to rig it up until you replace/repair part. Good wrenching!!
Old Sep 8, 2013 | 11:14 AM
chrome91's Avatar
take the door panel off, you can try jumping the switch to see if the motor is bad. if after jumping the switch it wont go up, its probably the regulator
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
