i REALLY NEED HELP. SAFETY CONCERN
Definitely need a new master pw switch, I think you can get one from rockauto. Don't bother going to a junkyard on that one, cause most of the others are shorted out too. Just my experience.
On The tail light issue, I can only make a few suggestions, buy new bulbs for that side, and go to a junk yard and pick up another inner tail light assembly with all your bulb holders in it.
I guess I should ask, have you disconnected that assembly and tried the fuse?
Yeah, test both of them separately when the other is disconnected, find which one is faulty and inspect it, replace the bulbs, ect. If you aren't sure about that splice job on the RH side, ditch it completely or rewire it correctly. A bulb shouldn't be burning holes in the plastic, brake light might have been on constantly.
Maxima278. Yea i went to the local pull and pay for a new light assembly, didn't really do much. The gxe light fixture did not fit properly in my SE ficture.
But do you guys think LED'S will help with the amperage problem?
Yesterday i put in a 20 amp fuse and it has been working fine since.
I just want to fix this problem once and for all.
Yea thanks for the rockauto link.
Hectic - yea i think my next step should be to remove all the bulbs and see which one is causing it
shiloh and chrome and all of you do you think new rims would fix the tire pressure problem??
you need to take that 20 amp fuse out NOW or youre gonna have bigger problems if you dont already.
your problem is still in your bulb sockets. either your parking lights are bleeding into your brake circuit or vice versa. you need to figure out that problem first
+1 wit 20A fse.
Dmad. - are my wires going to be damaged because they are meant for 15 amps.?
Lux- I think it tells me the numbers on the light fixture right? I'll check today. Do you think LEDs will help? I have older versions of the lights,I think the original.
Chrome- one of my tires kept losing tire reassure. 6 or so months ago I put slime in it
http://www.walmart.com/ip/16782749?w...068870&veh=sem
It worked for 6 months and recently started losing pressure again. Yesterday I put a refill. I think my stock 15's are corroded around the circumference. Perhaps it is puncturing the tire. I think new rims and tires is the solution?
Fire is eminent with a fuse over the amp specified.
Sylvania has a bulb finder site that is fairly accurate. Otherwise check your owners manual.
A new rim and tire will fix the slow leak.
Slime should only be used to help you make it home/emergency IMO. That stuff does nasty things to the inside of your tire. Off balance, etc.
...& why the splicing job on your rear light..?
I'm not understanding the purpose of that?
I had the same issue with my fuse blowing. Including with the lack of dash lights, I notice that one of those ground wires was loose from the plastic and touching other things, causing a short and blown fuse like yours. I agree, get a new assembly or a multimeter.
for the tire leak, get a mist spray bottle. fill it up with some dish soap and water and mix it. take the wheel off, and spray the tread of the tire. if anythings leaking, it will bubble up from the soap. it will be quite obvious
if theres no leaks on the tread, spray the area where the rim meets the bead of the tire. spray the inner and outer side, if it starts bubbling around there, your rim has corrosion on it. the tire has to be removed and the corrosion ground off with a grinder. any tire place can fix that, ive fixed hundreds of rims with rim corrosion
i havent really seen that Slime stuff fix leaks, ive removed tires to properly fix them where someone put Slime on the inside and that stuff reeks and burns your lungs lol
the reason the fuse is blowing is because theres too much in the circuit. the bulb is corroded to the point where your brake light is leaking into your parking light wiring, parking lights are only 8w but now they're joining up with the 27w brake lights -> why the fuse is blowing. it might not be the bulb but its either that or where the bulb makes contact in the socket, or wiring in the bulb holder.
also, the reason you hear that 'click' and have to use the shift lock button is because that runs off the same fuse, so if it blows that will happen. unplug one of the tail lights on either side completey. hit the brakes and if it blows then your problem is with that side. if it doesnt blow try the other side find your problem
adding a higher rated fuse will only allow that increased current to go straight to your TCU or whatever the box under the dash you're going to end up burning up with the higher rated fuse. NEVER USE A HIGHER RATED FUSE
Sorry you guys for the delay, I was waiting for a quote from my local Collision Center.
They said they can fix the master power control for $ 174 (labor included). Good deal?
And thank you Dmad and all others, i put a regular 15 amp fuse in .
define major?
is it going to blow up your motor...MAYBE...you have an oil leak. if you just keep it topped off your engine will more or less survive.
once that grease/oil hits the exhaust manifolds things will get a little stinky in the cabin.
change your PCV valve
Don't pay $175 to have your master window switch replaced. It's a 10 minute job and easy enough to find a working used one for little or no money. Literally everyone here has replaced at least one, so if you need help in any way, everyone here is qualified to help. Same goes for regulators.
Oil leaks from the VE valve covers are very common, you're looks a little worse than the typical case. Replacing it might make it worse or cause new leaks. Wipe that sludge off and keep an eye on it and the oil level. Take Dan's advice and replace the PCV valve, it's another 10 minute job and it's probably clogged to no end.
PCV valve just kinda reuses air in the engine, it gets rid of moisture from the crankcase and throws it into the intake manifold so it gets burned off and doesnt cause sludge
i think nearly every car in the last 30+ years have had a PCV valve, EGR some cars never
5 min search and i found this....
http://forums.maxima.org/3rd-generat...e-located.html
c'mon man...there's a search on the forum for a reason...please use it to help YOURSELF in fixing your car.
photo credit to greeny.
James92SE
Oct 8, 2015 04:57 PM
