Brake line clogged!?!
Old Nov 12, 2013 | 01:12 PM
84minieldo's Avatar
My rear passenger brake line is clogged no flow when pumping pedal... Front driver is slow drips other two squirt??? Any tips?
Old Nov 12, 2013 | 01:41 PM
ujm's Avatar
ujm
I doubt it's the line - probably at the wheel cylinder. Have you removed the bleeder all the way and looked in?
Could be the line....
Nothing to either side of the back?
Old Nov 12, 2013 | 05:05 PM
chrome91's Avatar
see if theres maybe a bleeding order for the calipers. brakes are a closed system, there should be nothing solid in there to clog up
Old Nov 12, 2013 | 08:57 PM
84minieldo's Avatar
The rear driver squirts when pressing pedal,drips from gravity, front passenger is same front driver drips with pedal , removed bleeder on the back, a bit rusty but not clogged,removed the rubber line where it connects to the metal line no flow, was able to blow thru caliper bleede thru the rubber line... put a tube on metal line,nothing,blowing or sucking, while pushing pedal-car off and on...master cylinder maybe...any one have a pic of which lines go to where coming from the abs unit in case I have to change the line...also if I use the rolled up brake line replacement line does it have to be the same length,routing as the old line or can I just run it from the abs to the rubber hose connect any way I want...sorry thx!
Old Nov 17, 2013 | 11:55 AM
84minieldo's Avatar
Bump/ help...any body...
Old Nov 18, 2013 | 03:04 PM
GluteusMaximus's Avatar
Master cylinder. I had the same issue you described in your OP and it turned out to be a bad master.
Old Nov 24, 2013 | 02:46 PM
84minieldo's Avatar
Hope u guys r right.. Name:  edeb5cff9f3d396e62132a264380d166.jpg
Old Nov 24, 2013 | 08:23 PM
84minieldo's Avatar
It was the master cylinder thx I'm goin again..er, well, stopping again
Old Nov 26, 2013 | 09:28 AM
Yay, good job! These maxi's sure have good brakes when they are working right. Is yours an ABS or non-ABS maxi?
Old Nov 30, 2013 | 03:32 PM
84minieldo's Avatar
Its abs..now I gotta caliper pin that seized..cleaned up waiting on the boot..
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
