what size tire i need
Are you planning to put a lift kit on your max. The oem tire size for the car is 205/ 65 /15 I have 18's but couldn't imagine going to 20" and even when you go to a larger rim you still need to reseach your tire size so you don't throw off your speedometer for example if you wanted to go 18's and keep a normal speedometer reading you would put 225/ 40/ 18.
don't you wish there was a section to discuss tires and wheels...
oh wait...there it is -> http://forums.maxima.org/tires-wheels-53/
don't you wish there was a tool to figure out what tire size to use...
oh wait...it's here -> http://forums.maxima.org/tires-wheel...nstration.html
the tire size that fits is 235-30-20...i assume the rim is 8" or wider.
its a rubber band...
This is true...I went with a 16x8, a little height and a bit of width. I have Toyo Proxes 225/50/16's and they fit perfectly...the odo is barely off but I have a digi dash and portable GPS that 'm clocking odo.
I went with 17s off of a 05 and they are very close to rubbing. The tires that came on them actually did rub but I put on new since and they are fine. Don't remember size but I can check if someone would like.
knight_yyz
Nov 1, 2015 01:34 PM
