1994 maxima instrument cluster-odometer
Old Feb 11, 2014 | 10:49 PM
bilpochai's Avatar
How do you get the odometer to work.The speedometer and all other instruments work fine. I have just installed another engine and need to keep track of the mileage.
Old Feb 12, 2014 | 12:30 AM
Hectic's Avatar
If the speedo works, then the odometer is most likely frozen. Unless the small connector to the odo is disconnected at the back of the cluster.
Wrong section though.
Old Feb 13, 2014 | 04:15 PM
ac max 92's Avatar
A friend of mine has the same problem with his 94. Let me know if you find the solution. I have a spare cluster but we haven't gotten around to swapping it out if that would even solve it? If he doesn't want to swap it then the cluster may be up for grabs. Im in Canada so I'd have to check about shipping if it's even an interest and provided he doesn't want to swap it but im sure you could also find one at a local yard aswell.
Old Feb 13, 2014 | 10:37 PM
jbbons25's Avatar
When my odometer stopped working, I tore down the cluster and it turned out that the gear attached to the motor was turning, but it wasn't making contact with the gear on the odometer. A little adjustment and all is well.
Goffery2uned
Aug 21, 2015 09:50 PM
Team STILLEN
Aug 10, 2015 04:29 PM
