Help! Wipers are dead.
It was snowing out last night and I had my wipers on. All of a sudden, I head clunk sound and the wipers just stopped. I could hear the motor going and the clunking sound continued. I moved one wiper with my hand and the other one moved with it. What the hell happened? I was so
b/c it was it was snowing pretty hard! Can anywone help me out? Thanks
Clark
b/c it was it was snowing pretty hard! Can anywone help me out? ThanksClark
I had something similar happen on my car. One wiper got stuck on the frost and popped out of the balljoint connecting the two arms together. Probably what happened to yours is it either broke or popped out of the joint connecting the motor to the common arm for both. Open it up and either just pop it back into place or if it looks worn, I'd replace the joint/bushing to prevent if from happening again. I just popped mine back in because I forgot to unstick the wipers from the windsheild, but you might want to replace yours. Good luck.
BTW, there's only ONE screw in the middle holding in the black cowl. The rest are just plastic pop-in retainers. Try not to bust these as they're kinda expensive for bits of plastic.
Clark, your an idiot, that was teh funney though, im just drivin 2 cars ahead of you and you callin mah cell "randy, my wipers are broke" "what should i do"...you moron, were were only a 1/2 mile from the resteraunt, couldnt it have waited till we got there
I took the wipers off and the middle screw off the plastic cowl. I pulled it up a little on one side, but how do I take the whole thing off? Im afraid to pull on it too hard breaking it. should I use a screwdriver or something? I just dont want to screw anything up.
As far as the ball joint thing, would that still be the problem if one wiper still moves the other one? because they both move when I move one of them. Thanks.
As Bman said, there's some metal rods connecting everything in there, and the ends are connected to ball joints with plastic tabs. I've sold one of them already, butit was the one on the far left (so the driver's wiper only stopped working).. Since both of your wipers stopped, and both wipers are still connected to each other, I'd bet it broke on either the motor end of it, or on the right wiper arm part.
Either way, you'll have to remove the black cowl piece to see what part has broken. if you're lucky, it just popped out of the socket, but I doubt that's the case. if something actually did break, shoot me a PM or email and I'll dig the parts off my parts car and mail them out to you aSAP.
lemme know.
lemme know.
and because I wasnt working on BST for once
lemme know.
lemme know.
Death to the wiper mechanism designer!
okay, I spent an hour and a half trying to fix this problem. All I have to say is WTF?!? It is a massive PITA!! I spent 20 minutes trying to get the old linkage off and another hour trying to get the new linkage on! Needless to say, I GAVE UP! It was snowing out, 12:30am, and I was getting
I didnt realize that there is NO leverage in there to pop the linkage on the motor. and the wiper side popped off it I moved it too much. So, I am saving this job until Saturday to try again if the weather is better. In the mean time, I am going to give my winshield another Rain-X treatment. Can anyone tell me if there is an easier way to do this? does taking the wiper motor off help? If this is the only way, so be it...I'll try again. but I hope there is.
Re: Death to the wiper mechanism designer!
markevans999
Sep 10, 2015 04:29 PM
CreativeSkillz
Aug 26, 2015 04:23 PM
