Por 15
Old Mar 29, 2014 | 06:25 PM
ac max 92's Avatar
Anyone ever use por 15 when doing their bodywork?
Anyone ever use por 15 when doing body work? Just looking to hear some feedback or thoughts on the product. Im having my wheel wells done with new metal welded in and having por 15 used after the patch work then spraying the wheel wells over with truck bed liner seeing our 3rd gens have the plastic sheilding in the front wheel wells but not the rears i notice the metal in the rear wheel wells takes it's toll after all these years. After this is complete the wheel wells should be solid and rust free like the rest of the car for many more years to come i hope. Especially since it's no longer winter driven.
Old Mar 29, 2014 | 07:09 PM
Fakie J Farkerton's Avatar
LOVE POR-15.
Great stuff.
Old Mar 29, 2014 | 10:42 PM
Nealoc187's Avatar
SLOW
i've used it. it's good.
Old Mar 29, 2014 | 11:42 PM
nismomaxgtr18's Avatar
Highly recommend POR-15.
Old Mar 31, 2014 | 02:04 PM
DanNY's Avatar
Adˇminˇisˇtraˇtor
depends what you use it for...
if it's totally rusted then it's not going to save it.
if it's surface rust then you can rescue it with por15.
have to make sure you prep it correctly.
also por15 is not UV stable so if it's a lighter color and it's in the sun it will turn color.
Old Mar 31, 2014 | 07:53 PM
ac max 92's Avatar
Thanks for the heads up DanNY, Im actually having new metal welded in on the rear wheel wells and was going to have it coated with por 15 before having the wheel wells coated with truck bed liner seeing the rear wheel wells on the 3rd gens don't have the plastic sheilding like the fronts.
Old Apr 18, 2014 | 08:34 AM
keener's Avatar
You should not have to use POR-15 and truck bedliner. It is either one or the other. POR-15 is very hyrdophobic, so I'm not sure bedliner will stick. Restoring muscle cars, I always prefer POR-15 over bedliner. Couple things to remember: make sure to wear gloves, otherwise your hands will be stained for weeks; remove the liquid from the can with a turkey baster or large syringe and place into a different container for application, this will avoid basically welding the cover back on to the can if some of the liquid remains on the lip; also quickly reseal the can after removing product to avoid exposure to atmospheric conditions.
willians hudiel
Sep 10, 2013 12:45 PM
cefiro8701
Wheels/Tires
Jul 15, 2007 09:42 AM
magobiasso
26
Jun 7, 2007 12:30 AM
DMad8724
Nov 22, 2004 12:17 PM
