Various Line questions with Pictures
Old Apr 5, 2014 | 03:09 PM
denclock's Avatar
I am trying to figure out what these lines are for. And also want to make Sure they are attached at the right place.
I found this line, and metal U just laying on the driver side, going from a Black block next the wheel well. I don't think this is just a drain tube.
This line I am not sure about, but noticed it hanging down from what I think is the carbon canister, I brought it up, and attached to the place shown here. Just want to make sure this is attached at the right place.
This line comes from the original heater control valve (you can see the bulky replacement) where they had 2 lines coming from it. The line that I have going to nothing (stuck a small screw into it). Should it be plugged into something ? it is the line that goes off out of the picture.
Thanks for any help. I imagine that these are all some vaccum line, but unsure.
Old Apr 6, 2014 | 05:30 PM
DennisMik's Avatar
If that round black thing (last photo) is for the heater water valve, the hose on it would have to be hooked up to vacuum, specifically the part just above it that has the other vacuum hose going to it.
Two questions:
1) Does the heat control work?
2) Are you absolutely sure the mystery hose goes to it?
Because I think that hose may be the breather line for the automatic transmission.
Old Apr 6, 2014 | 05:51 PM
jbbons25's Avatar
First one is the breather hose for the transmission. Leave as is.
Second looks correct.
Third
Originally Posted by jbbons25
I posted a pic I took to help out a little. The red dotted hose should go from to top of the valve to the bottom. The blue dotted hose should go to the intake manifold as mentioned on my previous post. Are you talking about the red dotted one?
matts95max
Apr 23, 2025 10:44 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Sep 10, 2015 06:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
