Ebay turbo needs rebuild (video)
Did you buy the turbo used? It seems to have failed early even for an eBay one.
Tony how did you resist that ice cream truck!? :laugh:
(Post 9110991)
Originally Posted by Tiniform
(Post 9110989)
it's probably metal burrs from manufacturing. it's due to poor QC on building the turbo from china.
"c-clip"...that's the name of the clip. it's also known as lock ring too. when you rebuild a turbo you're supposed to strobe light balance it. i doubt you have that equipment or the skill to do that...so just keep that in mind that it's not as easy as pulling bearing out and throwing them back in. the oil passage ways allows for the oil to come in and basically the journal bearing rides on a thin coating of oil. if you do decide to swap it out and throw it back together your turbo might live a short life. keep in mind that blade spins at like 100K RPM. in any event i doubt you'll listen to me and you'll do what you want to do anyway...so good luck. |
Originally Posted by DanNY
(Post 9111068)
"c-clip"...that's the name of the clip. it's also known as lock ring too. when you rebuild a turbo you're supposed to strobe light balance it. i doubt you have that equipment or the skill to do that...so just keep that in mind that it's not as easy as pulling bearing out and throwing them back in. the oil passage ways allows for the oil to come in and basically the journal bearing rides on a thin coating of oil. if you do decide to swap it out and throw it back together your turbo might live a short life. keep in mind that blade spins at like 100K RPM. in any event i doubt you'll listen to me and you'll do what you want to do anyway...so good luck. The godspeed turbo is going to be a backup turbo. I'm picking up a holset today and rebuild it before installibg it as my primary turbo. But just to let everyone know this EBAY TURBO godspeed is not crap, it actually works well. Stupid shredded pieces of metal from bad timing chain cause the journal bearing to wear out fast. I'm planning on doing 2 oil changes installing the magnetic oil bolt then ill install rebuild turbo |
Are you breaking almost everything you touch these days Tony Lol
Originally Posted by TonyJr
(Post 9111441)
I mark it so it can stay balance. Godspeed turbos come balanced. I can see the marking. But ill wont listen to you and do want i want to do jk lol.
The godspeed turbo is going to be a backup turbo. I'm picking up a holset today and rebuild it before installibg it as my primary turbo. But just to let everyone know this EBAY TURBO godspeed is not crap, it actually works well. Stupid shredded pieces of metal from bad timing chain cause the journal bearing to wear out fast. I'm planning on doing 2 oil changes installing the magnetic oil bolt then ill install rebuild turbo wait...how did a piece of metal end up there? your engine picks up the oil from the screened oil pick up and send it up to the engine (through the filter of course). how did that piece of metal get by? |
Originally Posted by ac max 92
(Post 9111450)
(Post 9111455)
ok as long as you marked it and it goes back at that same spot then you're good...for the most part.
wait...how did a piece of metal end up there? your engine picks up the oil from the screened oil pick up and send it up to the engine (through the filter of course). how did that piece of metal get by? https://cimg3.ibsrv.net/gimg/maxima....73fa23d5a1.jpg |
Finish rebuild godspeed turbo today. |
© 2024 MH Sub I, LLC dba Internet Brands
