stillen front brake question
That's for the set. but don't buy them. mine cracked in under 8 months. (about 12k miles).
If you REALLY want non-solid rotors, get the powerslot slotted ones. they run about $160 for the set, and you won't have to worry about the cracking common on stillen's crossdrilled rotors.
Originally posted by PATRICK94SE
This doesn't have anything to do with your post but, I have heard bad things about cross drilled
Originally posted by SkyMax
Then again, you also drive insane.. lol
i guess i should add that i have driven ~ 20K miles on them and i'm on my second set of pads... i kinda want them to crack so we don't have this debate about them anymore. it's not like i baby them or anything...
Re: stillen front brake question
Originally posted by flyry110
for the drilled rotors. . .. . . are tehy 220 apiece or a set?
Re: Re: stillen front brake question
I also used Metal Matrix pads, and followed the break-in period. My right rotor developd a crack in it large enough to stick your fingernail in in under 15k miles.. not very impressive, especially considering my stock rotors have nearly 60k of MUCH harder driving on them.
Originally posted by jwtarbaj
I don't know what happened but Matt93SE must have received a defective set of rotors. I have $tillen X-drilled rotors and am not easy on the brakes at all. I have had them for over 30K miles and they are just fine. I still have the $tillen pads that I put on with the rotors also. I think they work well and look good if you have open wheels. Just make sure if you buy them to follow the recommended break in.
Re: Re: Re: stillen front brake question
MAXSE5SPD
Aug 23, 2015 12:06 PM
sonic7
Aug 20, 2015 12:23 PM
MaxStock
Aug 14, 2015 10:01 PM
