power coil problem
Hello friends
Maxima 1993 My car only ran 4 machines, engines 4 and 6 had no electric spark, although the coil was replaced. Help me |
VE30DE engine im assuming with coilpacks?
first thing i would do is swap coils yet again, swap cylinder 1 & 2 out with 4 & 6. if 4 and 6 still miss, you know you didnt get bad coils. second, you can read the ECU in the cabin for flashes for trouble codes. might get an actual fault, might just get multi misfire code. theres a few threads how to get it to flash codes |
I changed my position but I still can't
How are you checking the spark? A ole school timing light will work if you place the inductive pick up around the coil pack pigtail! It's the easy way of viewing what's firing and what's not! If 4 & 6 are still missing swap the spark plug next and if they're still missing you either have a compression issue or an injector issue!
This is basic troubleshooting you have to know how to test and eliminate one system at a time!
© 2024 MH Sub I, LLC dba Internet Brands
