Fuel pump location
Old Feb 7, 2002 | 06:56 PM
catman316's Avatar
Fuel pump location
Any one know were is located the fuel pump in my vg?
I used the search tool and dont find anything.
Old Feb 7, 2002 | 07:17 PM
Sudesh's Avatar
Re: Fuel pump location
Probably under your back seat in the fuel tank.
Old Feb 7, 2002 | 07:38 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Fuel pump location
you are correct sir.
Old Feb 8, 2002 | 10:04 AM
Eric92SE's Avatar
All you have to do is pop your back seat bottom off, which doesn't require removing any bolts or anything - just pull it upward. You'll see a panel with 4 (if I remember correctly) bolts on it. Simply remove the bolts and lift the panel up, and the fuel pump is attached to it. Don't worry, it's not a very hard job at all, it took me about 15-20 minutes to replace mine in the driveway.
Old Feb 8, 2002 | 10:08 AM
catman316's Avatar
thanks man!!! I will try it!!
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
