Getting rims need a lil help!
Old Mar 1, 2002 | 07:03 PM
Booner8269's Avatar
Ok in like 2 weeks im going to get some Motegi 18x7.5 with a 45mm offset. Now i want to run 235/40/18, will this be a problem. My shop said to run 225/40/18.
Old Mar 2, 2002 | 07:24 AM
N34JZ's Avatar
Needs non-Maxima Friends
its fine
when I sell someone 18's thats ussually the set up we go with I've got 235 45's on my 17's. I had the same combo that you want when I had my 18's but the ride was too ruff so I went with the 17's. what brand tires are you getting. I sell SUmitomo,toyo etc...
XRR Custom Designs
Old Mar 2, 2002 | 11:44 AM
Bman's Avatar
Won't there be rubbing with 45mm offset, requiring a different selection or spacers? I know of one person (Mr.Rose) who got Konig Subzeros with 45mm and he had considerable rubbing with 235 tires so....
AFAIK, to run 235's you should go with 35 or 30mm offset.
Old Mar 2, 2002 | 12:12 PM
C-Dawg's Avatar
I was under the impression that 225/45/18 was the proper setup.
Check here for a tire size calculator.
Old Mar 2, 2002 | 12:14 PM
Booner8269's Avatar
So do you guys suggest 17's? I think those are 17x7 somthing like 40mm offset. So i could still run 235?
Old Mar 2, 2002 | 11:56 PM
Lordrandall's Avatar
You will probably rub with 235's and a 45 offset, without spacers anyway.
Old Mar 3, 2002 | 02:35 AM
Bman's Avatar
Things that will help (if you MUST get these rims):
-narrower tires (like maybe 215 width)
-spacers (but adds cost and work if you DIY)
-tires without a "rim protector" which is a layer of rubber that sticks out a bit to protect the rim lip.
Old Mar 3, 2002 | 09:38 AM
maxdout92se's Avatar
i seem to boggled with this same question...my question is, in a recent post, it was said that tha ride was too rough.....what is meant by too rough? A lot of noise, the ride is uncomfortable...etc?
Old Mar 3, 2002 | 01:04 PM
N34JZ's Avatar
thats my setup now
and only my fronts rub when I turn the wheel all the way, and that doesnt even happen anymore with no mud flaps.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
0m3nc0w
Sep 11, 2015 05:21 PM
