Can i just switch the electronic dash with analog?
Old Mar 11, 2002 | 08:32 AM
edpaek's Avatar
Cas I just replace the electronic gauge i have with an analog I have sitting around? It should be the same connections right? Unless someone out there is selling one?
Old Mar 11, 2002 | 08:45 AM
jim90gxe's Avatar
Re: Can i just switch the electronic dash with analog?
No the connections are different. But you can swap them if you feel like splicing wires. You will need the wiring diagram for both instrument clusters. Wire Colors will not always match up.The fuel guage will not be accurate. The fuel level send sends a signal from something like 30-1000omhs to the GXE digital dash. While the analog dashes get a signal from like 1-100omhs. So you will need a SE Fuel level sender. All your your guages might not be 100% correct.
The reason I swapped mine on my gxe is because the dash was completely dead. I wasn't willing to spend $1200 on a new one or $600 for a used one.
If yours is dead take it apart and look at the solder connection behind it. You might find one of the traces burnt.
Good luck.
Old Mar 11, 2002 | 11:39 AM
JD's Avatar
JD
If your dash is dead, you can have it repaired for about $300. That's what I spent last year and it still works great.
Go to this link for more info:
http://forums.maxima.org/showthread.php?threadid=23100
Old Mar 11, 2002 | 12:55 PM
The Sleeper's Avatar
hmm... digital dash displays... anyone know who it was that had the HUD that projected onto his windshield? i want one of those but i have regular SE guages...
Old Mar 11, 2002 | 01:08 PM
skatanic28's Avatar
how can ya give up white face gauges?
Old Mar 11, 2002 | 01:21 PM
not giving up white face guages... i just want a HUD!
Old Mar 11, 2002 | 01:50 PM
«§»Craig B«§»'s Avatar
you cant just add the nissan HUD to analog gauges, you need the main unit that drives the HUD and dash
not an easy project either
they do sell some really expensive aftermarket HUDs, but I dont think it's worth it
just hire a friend to yell out your speed every 5 seconds and you'll save your money that way
"88 miles per hour!"
Old Mar 11, 2002 | 02:11 PM
JD's Avatar
JD
I have the HUD because of the digital dash. I use it occasionally to entertain my son, lol. Not worth the trouble or expense. More distracting if anything. I'll try to get a picture this week and post it......
Old Mar 11, 2002 | 02:19 PM
DanNY's Avatar
Ad·min·is·tra·tor
or when good ole smokie decides to whip out his "speed measuring tool"..he'll let u know how fast you're going.
gavin68
Sep 18, 2021 12:36 PM
magiconthetire
Oct 26, 2015 09:03 PM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
