gas smell on 92 max
Old Mar 19, 2002 | 07:38 AM
phat's Avatar
gas smell on 92 max
i am a recent 92 max owner. I smell gas by the gas tank. i've a hissing noise similar to a flat tire. I replace the gas cap. The hissing noise goes away, but the gas smell is still there. I also replace the fuel canister, but nothing changed. In addition, my lock/unlock doesn't work all the time. I'm stuck. Can someone help me. My max is a 92 se with 63,000 miles.
Old Mar 19, 2002 | 07:52 AM
Jeff92se's Avatar
I'm needing a caw
When the car is cold, open the hood then start the engine. Follow all the fuel lines and look carefully. One or more of the rubber lines are probably leaking at the hard line connections. You should replace the leaky hoses w/ quality fuel injection hose avail at most auto stores.
Old Mar 19, 2002 | 11:54 AM
bucketheadd's Avatar
If its coming from the gas tank it could be the filler tube. Theres a recall for that and they`ll fix it for free.
Go here http://www.nhtsa.dot.gov/ and check the recall history out. Then call this number, 1-800-647-7261, its Nissans coporate number, and see if you have any open recalls. If so call your dealer and have them fix it.
Old Mar 20, 2002 | 06:26 AM
phat's Avatar
gas smell on 92 max
Thanks for your help guys.
Old Mar 20, 2002 | 08:07 AM
Giovanni's Avatar
I had the same problem on my max. It was the vent line (fuel return line) on the gas tank. Nissan quoted $25 for the fuel hose (less than 2 feet) but I got a similar FUEL hose from Advance Auto Parts for less than $5 ;-))
shilov
Feb 19, 2024 09:40 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
