master cylinder/slave cylinder
Old Mar 22, 2002 | 10:53 PM
flyry110's Avatar
ok, so as everyone has probably read, and gotten sick of reading, i've been having shifting problems. well, i've actually noticed that i've had to put clutch fluid in every couple of weeks. at first i thought it was just the clutch getting worn, but i'm pretty sure it's not now. with the notchy shifter, and when i push the clutch real fast and hard, it's easier to shift, i think it's my master cylinder. . . . what do you guys think? i mean, it's hard to shift, and i have to wait for the synchros to line up before it'll go into the next gear. and from a dead stop it's hard to go into 1st. . . .. what do you guys think? master cyl possibly?
Old Mar 22, 2002 | 11:16 PM
flyry110's Avatar
nopi has em for 25 bucks. . ..
Old Mar 25, 2002 | 08:24 AM
bjyang
sounds like mine.....changed thee master and slave cyclinder....easy job..but it wasn't the problem!!!! The problem is still yet to be discovered!!
Old Mar 25, 2002 | 11:47 AM
Matt93SE's Avatar
STFU n00b!
If you have to add fluid that often, then you should be able to find where it's leaking. look behind your pedal under the firewall.. there's a rubber seal on the inside of the MC that was leaking fluid inside the firewall on my car. rebuilt the master cyl and the problem went away. shifting improved , but most of the benefit was from changing the clutch and rebuilding the tranny.
Old Mar 25, 2002 | 03:31 PM
Bman's Avatar
Hmm.... almost like when I shredded the seals on a brake MC I bled once. It was all leaking out the back into the vacuum booster and filling it up!
Old Mar 26, 2002 | 06:43 AM
flyry110's Avatar
thanks matt, as soon as my car thaws out i'll check it out. it's encased in ice right now.
Old Mar 26, 2002 | 07:59 AM
Matt93SE's Avatar
STFU n00b!
Wheee fun.
you take my exams this week and I'll thaw your car out.
today: Control systems
tomorrow, Statistics and Electronics II
thursday, Electromagnetics
friday, Electronics II lab is due (about 50 hours of work which I haven't had time to do yet).
ugh.
Old Mar 26, 2002 | 09:06 PM
John van de Pol's Avatar
same as MAtt's -->
Mine lost fluid, and it was leaking on the inside into the cabin. Not a trace of a leak outside. I rebuilt mine with an oem kit from Courtesy.
John
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
