help help help!
Old Mar 30, 2002 | 08:31 PM
KLoWnPR109's Avatar
help help help!
I rewired my corners tonight and they worked fine. But when I was driving home, they went out along with the light on the shifter that illuminates what gear you are in, and the gauges. Did I blow a fuse or somethign? Headlights still work. Interior door lights still work. I followed the directions on Craig's page exactly. What could it be? Please reply because I want to go ahead and fix this tonight.
Old Mar 30, 2002 | 09:03 PM
PATRICK94SE's Avatar
Re: help help help!
Did you check your fuses?
Check all yor wiring make sure nothing is exposed.
Old Mar 30, 2002 | 09:46 PM
KLoWnPR109's Avatar
Problem solved. I just blew out the tailight fuse. Thanks PATRICK94SE!
Now that my corners are brighter, I just have to find some new bulbs to match my white headlamps.
Old Mar 30, 2002 | 09:52 PM
I forgot to mention in our conversation you might want to double check you wiring...fuses usualy blow for a reason. You may just need to get a higher Amp fuse?
Old Mar 30, 2002 | 09:54 PM
KLoWnPR109's Avatar
Well, I searched after I made my post, lol. I read somewhere that its better to use a 15? fuse and that the reason they blew is because I overloaded the circuit. So, I'll probably go to the store tomorrow and buy a 15 just to be safe.
Old Mar 30, 2002 | 09:59 PM
ngthing's Avatar
Next time you short something, instead of your fuse blowing, something else will go.
Old Mar 30, 2002 | 10:08 PM
KLoWnPR109's Avatar
such as.......... I dont really understand what you're saying?
Old Mar 30, 2002 | 10:39 PM
ngthing's Avatar
such as an electrical fire
Old Mar 30, 2002 | 10:43 PM
He is saying the higher amp fuse will be more resistant to blowing and may not blow in time
Old Mar 30, 2002 | 10:48 PM
maxima_dumby's Avatar
When i was trying to install my own headunit, i screwed up badly and blew the taillight fuse AND something else. I have replaced all the fuse since then but i still can't figure out why my tail light works but not my gauge and shifter light doesn't. I have also replaced the interior dimmer switch but still no success. So does anyone have a solution to my problem?
Old Mar 30, 2002 | 10:52 PM
ngthing's Avatar
have you checked the acutal bulbs?
Old Mar 30, 2002 | 10:55 PM
yeah i checked everything
even swapped gauges to see if it works, but still doesn't work. I checked and there is power going into the bulbs just don't know why it isn't working.
