Clueless - Front Crank Seal
Old Mar 31, 2002 | 01:08 PM
blackandwhite's Avatar
To them I'm like an idol
I am trying to replace the crankseal that you are suppose to replace when you do the UDP. Where does it go? I have the chilton's manual, but I don't see it.
Old Mar 31, 2002 | 11:48 PM
kaleb's Avatar
Re: Clueless - Front Crank Seal
Behind the crank sprocket. You have to remove the timing belt but it's not that big of a deal because you just have to mark the teeth. The hard part is the crank sprocket. You'll want a 3 jaw puller or you could try to use a hammer and punch to get it off, but I recommend the puller.
-Kaleb
Old Apr 1, 2002 | 12:36 AM
Re: Re: Clueless - Front Crank Seal
-Kaleb
Kaleb,
I went out to starbucks, but it was early and I couldn't stay long. I may be out at courtesy tomorrow, I need the ajustment bolt for the AC idler pulley. If you have to work, bring the lugs nuts with you.
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
dvcamp
Sep 18, 2015 10:17 AM
boomerbrian
Sep 2, 2015 03:46 PM
