pcv question
Old Apr 9, 2002 | 08:46 PM
maxdout92se's Avatar
pcv question
I have a SE and i recently changed the valve, but when changing the valve, i couldn't remember if the old valve was screwed all the way down or if some thread was left!! With the new valve i have, i can only get it to screw on half way and i'm scared to really put in some elbow grease cause i don't wanna mess anything up if its not suppose to screw all the way down!! Any other person have or has had this problem?
Old Apr 10, 2002 | 06:58 AM
SuDZ's Avatar
Re: pcv question
Is it an OEM valve or some other company?
SuDZ
Old Apr 10, 2002 | 07:19 AM
ChrisCheezer's Avatar
Re: pcv question
i left almost 2 threds out. it gets very hard to trun at one point but at 1 thred left it just stoped..
Old Apr 10, 2002 | 02:15 PM
Jeff92se's Avatar
I'm needing a caw
Don't force it. As long as it's fairly tight and seals, it's fine. If you overtighten the valve, it might strip the alum head(BAD), crack the head(EVEN WORSE) or break the valve inside the head(ALMOST AS BAD)
Old Apr 10, 2002 | 02:28 PM
thanks guys...thats what i wanted to hear!!
Old Apr 10, 2002 | 03:00 PM
eric93SE's Avatar
You should get into a habbit of using anti-seze grease whenever tightening things like that (anything into the motor or exhaust), Incase you have'nt already.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
