need help asap, please
Old Apr 9, 2002 | 08:55 PM
matt1sd's Avatar
ok, i made a dumb move. i was trying to clean my contacts in the master window switch, and i decided to take the whole thing apart to see what the green bulb looked like inside. i tried to put it back together, and i accidently snapped the circuit board. im really ****ed. i have my windows down right now, and i cannot roll them up. man i feel dumb. i was just wondering if there is any release switch or something so i can get my windows back up for now? i cant have my windows down at school tomorrow. any help would be appreciated. thanks.
Old Apr 9, 2002 | 09:18 PM
Matt93SE's Avatar
STFU n00b!
Re: need help asap, please
If you know what you're doing with the wiring, pull the door panel off and find the connector on the regulator motor.. give it +12V on one wire, and ground on the other. if the window doesn't move or goes down, flip the wires around and do it again.
be careful, and I would suggest wiring a 5-10A fuse in line with it just in case, but you should be okay. I've done this several times in the past on my car when I had a similar situation.
Old Apr 9, 2002 | 10:54 PM
matt1sd's Avatar
Re: Re: need help asap, please
i read this, and i said, i dont want to mess with electricity and wires. but then i realized i had a cigarette lighter adapter cut off from a black light that i wired to my car. so i used it, and hooked up the other wires to the window regulator. it worked! im a frickin genius! thanks for the help.
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
