i really need help please
Old Apr 10, 2002 | 08:50 AM
Damion's Avatar
please help quick
my car wont crank over i think its the nuteral safety switch where is this switch and does anybody know how i can bypass it???
Old Apr 10, 2002 | 08:54 AM
ChrisCheezer's Avatar
Re: please help quick
humm.. what do you mean it wont crank..? does the key turn? does the starter turn?
Old Apr 10, 2002 | 08:55 AM
Damion's Avatar
the key and everything turns but the starter motor wont turn i think the switch is not working
Old Apr 10, 2002 | 08:58 AM
pj93max's Avatar
have you tried:
putting it in P - then trying to turn on the engine
putting it in N - then trying to turn on the engine
Old Apr 10, 2002 | 09:39 AM
Damion's Avatar
yes ive tried to put it in p and n but it still wont go where is that sensor located and how can i bypass it for now??
Old Apr 10, 2002 | 09:49 AM
kaleb's Avatar
Do you have an automatic? If so,
The switch is on the transmission, if it's bad you'll have to jump the connector on the harness side. You can use a spade-type connector like that goes on the end of a wire and then you slide into one of those screw-down connection points on like an amplifire. The spade connector looks like a fork. I can't explain which harness it is exactly, however, so it's gonna be hard to tell you what to do. I can get the wire colors off my car.
What you'd have to do is unplug the harness from the transmission, jump the wires on the harness, start the car. Un-jump it, plug it back in, then drive it.
This is assuming the inhibitor switch on the automatic is the problem.
Old Apr 10, 2002 | 09:50 AM
Matt93SE's Avatar
STFU n00b!
it's on your shifter, underneath the covers for the center console. how to bypass it is up to you. shouldn't be too hard to figure out though.
Old Apr 10, 2002 | 10:16 AM
Damion's Avatar
so where is this harness??? what are the wire colors i think that the switch under the shifter is for the key lock. Im pretty good at wiring( i used to install stereos) so if someone can tell me where the harness is and the wire colors then i should be able to get the rest BTW its a 1989 auto
Old Apr 10, 2002 | 12:40 PM
Damion's Avatar
Old Apr 10, 2002 | 03:00 PM
N34JZ's Avatar
Needs non-Maxima Friends
Re: i really need help please
do yourself a favor and follow these instructions.
1)read all the instructions first (take notes if you have to)
2)scroll up
3)read the entire thread (be sure to read the responces by Matt and Kaleb)
4)smack your self in the head(see figures 1.1 and 1.2) while saying one of the following: OOOOH,DOH, AHHHH
5)delete this thread
figure 1.1
figure 1.2
