codes
Old May 1, 2002 | 07:14 PM
jaredb03's Avatar
codes
I pulled codes from my ECU tonight and it came up with (12), (13), and (33). I have a 92SE. if anyone could tell me what these are i would appriciate it. Thanks much
Old May 1, 2002 | 11:10 PM
Booner8269's Avatar
Were do you guys get these tools to read codes? Dealer? Price?
Old May 1, 2002 | 11:42 PM
crazy4maxima's Avatar
write up please
i too are interested.. all i know is that you need a screw driver and the ecu
Old May 1, 2002 | 11:52 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Haynes manual has all the info to do the diagnostic.
and Jared I have the codes for my VG, not sure if they are the same but I'll post them tommorow afernoon when I find my manual if you still need 'em.
Old May 1, 2002 | 11:53 PM
what page
i have the hynes manuell but its in the car.. the car is in the shop..
Old May 2, 2002 | 04:02 PM
DA-MAX's Avatar
Hmmmm......now that I look at my ECU codes, I'm thinking its different for the VE, when I get my codes I don't get numbers like that I count the light flashes on the ECU...I'm confused???
Old May 2, 2002 | 05:46 PM
«§»Craig B«§»'s Avatar
VE is different
VG has 2 lights, one red one green, each one represents a different digit with it's # of flashes
VE has one light and does a couple long flashes and then some short flashes for 10s and 1s
Old May 2, 2002 | 05:49 PM
davis4005's Avatar
12=Air Flow Meter Circuit
13=Engine Temperature Sensor Circuit
33=Exhaust Gas sensor circuit
Invest in a Haynes and Chilton's manual, there worth the money. And I hope this helps
Old May 2, 2002 | 06:34 PM
Bman's Avatar
Keep also in mind that if you're fixing the car and removing things, etc., and run it or switch it to "on", you can generate trouble codes too. If you're unsure just blow the codes away and drive it for a bit so it makes fresh trouble codes.
Old May 2, 2002 | 07:13 PM
jaredb03's Avatar
circuit
what do you mean by "circuit"? is that the power going to the sensor or what?
Old May 2, 2002 | 07:29 PM
Jaybird180's Avatar
I'm not sure if I have the VE or VG, but I do know that I have the SOCH GXE. When I tried to follow the procedure in the Haynes, it didn't go the way described. I got both green and red flashing together, and they were all about the same in duration. Plus I got codes that were not in the manual. On top of that, it says to wait for 3 flashes and then turn back counterclockwise and then read the codes. When I did that, I got no flashes at all. Can someone please post the procedure?
Old May 2, 2002 | 07:49 PM
jaredb03's Avatar
engine temp sensor circuit
where is the engine temp sensor circuit?
Old May 2, 2002 | 07:54 PM
yeah, they do both flash in unison; I forgot the VG procedure, sorry
Old May 2, 2002 | 08:03 PM
davis4005's Avatar
$12.00 for a Chiltions or haynes manual at any auto parts store...
Old May 2, 2002 | 09:08 PM
Bman's Avatar
I agree, because Step 2 is to diagnose those sensors/controllers or check them.
If the computer spits out a error code it's telling you, "Hey, I'm getting no reading or a funny reading from this thingamabob - help!"
Old May 2, 2002 | 11:05 PM
Booner8269's Avatar
Ok you guys are saying read the number of blinks, but doesnt nissan have a hand held thing that you just hook up and it says all???
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
