Intake resignator removal??
Old May 3, 2002 | 10:56 AM
KingKong8247's Avatar
Hey, ok I have searched and maybe I wasnt typing in the right words or I just cant find it but how exactly would you remove the intake resignator? I know it doesnt add any power I just wanna here what it sounds like and is it possible to remove it without cutting anything so you can put it back on? I have a 90 Maxima SE Thanks for the help.
Old May 3, 2002 | 10:58 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Intake resignator removal??
you spelled it wrong, try serching with "resonator"
Old May 3, 2002 | 02:26 PM
Hey thanks I spelled it the right way when I searched then I searched again and I found a website in one of the threads that helped a little bit. Thanks
Old May 3, 2002 | 05:47 PM
KCMax's Avatar
DA-Max
When's your car going be fixed? I haven't started looking for those injectors yet b/c finals and all. For some reason, if I let my car sit idling for a minite or two before I turn it off, it doesn't screw up when I turn it back on.
Old May 3, 2002 | 06:23 PM
DA-MAX's Avatar
Re: DA-Max
well I ordered the injector on Tuesday, so they should be here early next week I'm hoping....I think after next week I'll actually get to do them though,I have finals the week after next so this coming week is gonna be CRAM TIME, no time to mess with the car!!!
hmmmmm, you're lucky if its working like that, with mine you could let it sit for hours and it would be the same rough idle, etc.....have you decided what you're going to do?? and did you try that mehtod I told you about to find the "bad" cylinder??
Old May 4, 2002 | 08:56 AM
flyry110's Avatar
ok, first off i'm gonna assume you know where and what the resonator is. second off, i'll tell you i noticed no difference in power or sound.
ok, all you do is pretty much pull the bolts that hold the bottom of the resonator, and then unclamp the top of it off the intake hose. then you need to find something to plug the gaping hole. In my case, a jar lid (i know wierd huh) fit perfectly.
Old May 4, 2002 | 12:30 PM
KCMax's Avatar
Re: Re: DA-Max
No, it's cram time for me right now too! I have Business Law Final here in an hour and a half that I've been in the library 2 whole days for. It's going to be brutal!
I haven't got to my car yet, but when I get home, it's spring cleaning and repair time!!!! Yehhaaaaa!
Old May 5, 2002 | 01:00 PM
bigjay's Avatar
res pulls of after clamp loosening, just pull real hard i won,t break
Old May 5, 2002 | 02:22 PM
flyry110's Avatar
don't forget you ahve to plug that big hole cause it's after the MAF
Old May 5, 2002 | 06:50 PM
PATRICK94SE's Avatar
My turbo pipping fit perfect in that hole
James92SE
142
Jan 2, 2024 09:23 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
