Where can I find the 93's keyless entry code
Old Nov 28, 2000 | 03:35 PM
spike
I bought a used 1993 maxima from a dealer and they said they didnt know the code. can anyone tell me how can i find the code (if its somewhere inside the car) or what do i have to do to get it or reprogram it...
Spike
Old Nov 28, 2000 | 03:51 PM
«§»Craig B«§»'s Avatar
go to http://www.kalebonline.com and then to maxima garage and then FAQ
the info you need is in there
the number is on a silver box between the glove box and the passenger's side of the car
Old Nov 28, 2000 | 03:57 PM
visions-kru
Ok first get a flashlight and, if your back is stiff, someone more flexible. Open the front passenger door and slide the seat back. Get on your back and with the flash light, look up under the dash, toward your left (this would be on the door's side of the dash). You should see a brass colored box with a wire harness and wires attached to it. You might see a label that says "Digital Touch Entry Control Unit" or something like that. You should also see two or three lines of code on the label. One of the lines should begin with the letter "S". Record the last 7 NUMBERS on that line, that's the master key number (well it should be).
Now, wiggle out of the car and shut the door. Press the button labeled "C"/"ST", where "C" is on the top and "ST" is on the bottom. Now enter the seven digit master key and you should hear a constant tone sound, during this period, enter a 5 to 7 digit entry key, this cannot match the master key. There also cannot be three digits in a row that use the same button, I.E. 909xxx or something like that. After you've entered the code, wait for the tone to stop, press "LCK"/"9|0" to lock the doors (HAVE A KEY READY JUST IN CASE YOUR CODE DOESN'T WORK STUPID!). Now press "C"/"ST" and enter your new code, the doors should unlock, if the doors do not unlock, press the "WDW"/"5|6" key and see if your front windows roll down. If they don't, the code operation didn't work,
Old Nov 28, 2000 | 04:33 PM
yeah, that is just what kaleb's site says
like I said before, just look at http://www.kalebonline.com
mvm062
Nov 30, 2020 09:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
