300zx flywheel?
Old May 7, 2002 | 05:56 AM
MaDMaX024's Avatar
300zx flywheel?
i was wondering, in order to save some money, would an aluminum N/A 300zx flywheel work on our cars?
i was wondering because no place around here will lighten my stock flywheel, and i can get a Z FW for pretty cheap ($250ish)
i know the clutches are basically the same, so i was wondering the the flywheels were..
Old May 7, 2002 | 11:52 AM
Nismo87SE's Avatar
They could be the same. I'm sure the part #s are different though. However since they use the same clutch housing and disk it should bolt up.
Old May 7, 2002 | 11:53 AM
flyry110's Avatar
the clutch housing and disc from a max will bolt to the flywheel, but that doesn't mean that the bolt pattern is the same for the flywheel to the crank. I bet that's what's gonna determine if it fits. also, whether it'll fit onto the crank. My aluminum one was a really tight fit. . . .
Old May 7, 2002 | 11:55 AM
MaDMaX024's Avatar
hmm...who would know for sure? i dont know much about flywheels, but isnt there more to it than just bolting up?
should i just call nissan?
Old May 7, 2002 | 01:56 PM
flyry110's Avatar
bolt it torque it. . . .dude, why do you want to put a Z flywheel on your max? 250 for an aluminum Z flywheel? call JWT. . . .
Old May 7, 2002 | 05:40 PM
blackandwhite's Avatar
To them I'm like an idol
Been there, done that
It does not fit. I know because I had the guys at Fidanza (www.aluminumflywheels.com) check for me. However, they will be make a flywheel for the VG, VE, and the 3.0 VQ with the next 2-3 weeks, when they finish they are going to let me know, and I will try to run a group buy, should be well under $400.
Old May 7, 2002 | 06:31 PM
MaDMaX024's Avatar
JWT is around $500, isnt it?
i just need to make my clutch last until graduation, then i'm taking half of what i get and putting it right into my car, hopefully selling my OEM clutch kit (opened once to look at it) and getting ACT street clutch, hopefully my tranny wont self destruct.
Old May 7, 2002 | 07:42 PM
flyry110's Avatar
i just figured JWT could answer your questions. . .
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Excalibur23
Oct 13, 2015 04:33 PM
