upgrading injectors, a quick question if these will work
Old May 7, 2002 | 07:29 PM
flyry110's Avatar
when i was searching for info on this, i found that NA Z injectors are an upgrade from ours on our maximas. However, i put up a post asking if anyone had any NA Z injectors and someone with a set of TTZ injectors with 40k miles on em emailed me. He only wants 100 bucks plus shipping. thing is i couldn't find anything on TTZ injectors. i was hoping some of the nissan buffs would know if the resistance is correct. I believe it was like 12.8 or something, i'll have to look it up again. anyway, help if ya can, if not, it's cool
Old May 7, 2002 | 07:32 PM
Nismo87SE's Avatar
NA Z injectors are not an upgrade. They are the same 259cc size. It is the turbo's that are 370cc and upgrades. If you wanted to pick up cheap injectors buy some MSD 36lb/hr made for a mustang and make a custom fuel rail. This should run you right under $300, but you need something to control the fuel. S-AFC at the minumin if you don't use resistors.
Old May 7, 2002 | 07:39 PM
flyry110's Avatar
so TTZ injectors won't be plug n play huh. . . . hmmmmm ok cool, thanks
Old May 7, 2002 | 07:52 PM
Maximamike's Avatar
And if you really wanna go big, get older Rx7 turbo injectors. They're 720+ cc's and very cheap. Of course you might need to wire some resistors in if they aren't the right resistence but that should be a problem. BTW, a S-AFC only will work up to 10% increase in injector size. 370's are a 30% increase over stock. No go...
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
no upgraded injectors will be "plug and play" without ECU revamping....
Old May 7, 2002 | 07:55 PM
Nismo87SE's Avatar
I believe you got the S-AFC confused with the fields fuel controller. The S-AFC is good up to 40% but I read that the fields was the 10% increase. Of course I could be wrong though.
Old May 7, 2002 | 07:56 PM
flyry110's Avatar
looks like ry needs his ECU. . . . too bad i have NO $!!!!! grrrrrr
Old May 7, 2002 | 08:17 PM
Matt93SE's Avatar
STFU n00b!
unless you're going to go crazy with needed power, youd be better off to buy an FMU and just bump up the fuel pressure.
this will be good to about 300hp. (i.e. look at the 4th gen SC guys. they're running the same size injectors)
Old May 8, 2002 | 12:09 PM
MaDMaX024's Avatar
are NA 300zx injectors plug and play or not? i'm going with what matt said, FPR/FPG, bumping pressure.
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
sonic7
Aug 20, 2015 12:23 PM
classymax420
Aug 6, 2015 06:35 PM
kenc15
Aug 5, 2015 08:29 AM
