What is this ME VI?
Old May 9, 2002 | 09:41 PM
JDwyer2821's Avatar
What is this ME VI?
Will this fit VE's? Are't VE and VQ somewhat simular? I want more Hp
Old May 9, 2002 | 09:53 PM
SeaMAX's Avatar
Middle East Variable Intake...
As whether it will fit a VE I don't know.
PATRICK94SE's Avatar
Re: What is this ME VI?
It is the Variable intake manifold for VQ that is not availible in the US. I Doubt it would fit the VE. If you have a five speed why try to fix something that is not broke? If you are auto you would have better luck trying one off of a wrecked VE 5speed
Old May 9, 2002 | 10:27 PM
JDwyer2821's Avatar
Re: Re: What is this ME VI?
I'm lost
Old May 9, 2002 | 10:34 PM
Jeff92se's Avatar
I'm needing a caw
Sheesh, if you have a 5-sp, you already have one. If you are auto, you can probably fit one from a 5-sp and set it up exactly the same as what the 4-gen guys are doing.
Old May 10, 2002 | 02:08 AM
JDwyer2821's Avatar
VTC=ME VI
Old May 10, 2002 | 02:57 AM
Do auto VEs have VTCs? grr.
VTC=Variable Cams
VI=Variable Intake(Variable intake runner path)
ME VI= Middle East(where they get it from) Variable Intake
Old May 10, 2002 | 03:04 AM
VTC=Variable Cams
Might as well get this out of the way and end this.
All VEs have VTCs
VEs in cars that came with a 5-spd Have Variable Intake Manifolds
I believe the longer path helps out with "low end power". And then the shorter path helps provide the VE with it's infamous "top end power".
Old May 10, 2002 | 06:52 AM
Mizeree_X's Avatar
Getting back to his roots
Questions
I was thinking about switching out the manifolds. I have a question though: is this a DIY job? I only have hand tools and an electric drill. Do I need more torque to torque down the manifold bolts? Also, in an earlier post on this subject, someone mentioned that I'd need to modify the ECU so that it could activate the vaccuum actuator. Is this true? I've never seen a 5-spd's engine, so I don't know how the system works.
Old May 10, 2002 | 07:31 AM
Matt93SE's Avatar
STFU n00b!
If you have to ask stuff like that............
Old May 10, 2002 | 10:24 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
*class finishes the quote* "....then you shouldn't be doing it!"
Old May 10, 2002 | 10:42 AM
JDwyer2821's Avatar
OK I'm found
