Working on Knock Sensor, oh boy
Old May 24, 2002 | 05:11 PM
eric93SE's Avatar
So I'm in the middle of it right now. Its just like other members have posted, the terminals are all corroded. There is a technical serive bulliten for this problem. Unfortuanatley its a lot of work to get down to it and do a good job. I'm hoping this has something to do with poor fuel economy, I'll be posting results in performance as well. The TSB says that the timming is retarded dramatically, something like 8-10 degrees during WOT (so its affecting 1/4 mile times as well). In the next comming week I'll be getting dyno work done (courtesy of Unorthodox) and then results for the new UDP from them will be posted. The max was running excellent before this project, so I'm excited to see what else I've been missing
Just to mention if any of you are crazy enough to do this job (its not that bad really), but you should definitley open both cylinder coolant plugs. b/c the cooland ****ed all over the middle of the engine while I was in the middle of it. And also to mention to all of you guys that wash your motor, DONT b/c There is a nice reservoir that forms in the middle of the engine under the intake manifold (like 3 inches deep) and it does not drain out. The pond will submerge the knock sensor making the teminals worse. I plan to seal the knock sensor with RTV silicone to prevent moisture from getting to the terminals in the future.
Old May 25, 2002 | 07:05 AM
wojtekj's Avatar
Re: Working on Knock Sensor, oh boy
Hi,
That what happened to me after washing my engine (92 SE auto), i've started experiencing loss of power as well as engine shut downs during any speed and also causing tranny to go beserk sometimes. Can it be due to the knock sensor terminals corroded?
I've tried everything pls post some more info of how to get down to it. Thanks.
Old May 25, 2002 | 09:55 AM
eric93SE's Avatar
I dont think the KS is whats causing your trouble. Its probably another connector that needs to be cleaned. You wont feel any poor drivability from the KS terminals being corroded. But there is a big performance loss due to the timming being retarded by the ecu.
Some general info:
resistance: before ~~(4) Meg ohm
After cleaning ~~(.5) Meg ohm (the same as another member who had tested a new KS)
So the resistance of the KS can be tested to see if the terminals are badly corroded or not. For those who do not know where to accesible connector is I'll try to position it for you. It's on the right side of the motor (side with battery), a couple inches away from the transistor pack or camshaft sensor towards the cabin. So the connector has two terminals but only one is actually being used (they must have had some reason for this, may have to do with the operation of the pezoelectric element), so you would have to check resistance between one of those terminals and the neg. on the batt. (or another ground spot). remember that one terminal does not do anything, so you would have to check both to find the right one.
The terminals on mine were so corroded that when I pulled the connector off the KS, that there was a small cloud of oxide dust, and the damn connector was sticking like glue. I'm still not dont with the job b/c I have to let all the silicon cure fully. I'm really looking foward to doing a test drive, I want to see If I can melt some tire rubber with my auto.
Old May 26, 2002 | 12:18 PM
eric93SE's Avatar
So no melting of rubber (damnn that LSD). But there is a noticable increase in low end. I hope this is going to solve my poor fuel economy, just about everything else has been replaced/tuned-up and the car is running really good.
When I was installing the throttle cables I tightened down the wrong nut and it pulled the TB, so when I started the engine up it was racing, didnt take long to figure it out. But no real problems were incountered with the job.
Next stop Unorthodox.....
Old May 26, 2002 | 09:48 PM
eric93SE's Avatar
So now after driving it another day I have found that the increase in low end is pretty significant. It now pulls with more low end than it is with high end. Before it was the opposite, go figure.
Old May 26, 2002 | 10:13 PM
MaDMaX024's Avatar
do you have functioning VTC?
new coils?
new injectors?
also, anything i should know before tackling this job (replacement parts, tools..)
Old May 27, 2002 | 10:04 AM
eric93SE's Avatar
Yup functioning VTC's
Yup just recently removed, cleaned, and installed all new seals on the injectors.
Yup all ignitions coils have been replaced within one year.
Here is a link for the injector job I did. I do reccomend doing this if you wanna do the knock sensor at the same time, I wish I had!
http://forums.maxima.org/showthread....ht=pintle+caps
I highly reccomend the kit beck arnley makes, its complete, and a resonable price!
Just one other thing I'd like to mention. The intake manifold gasket is VERY expensive. Dealer wants like $90/each. Aftermarket prices vary. I did decide to reuse the originals (they are thick steel, with rubber inserts) and I used a high temperature permatex gasket maker around all the sealing surfaces.
Old May 27, 2002 | 11:45 AM
Aphrodisiac's Avatar
you know this might be a stupid request, but I dunno. I'd like to see all these kinds of posts dedicated in a certain section so people can refer to them.
Yeah i realise there is a search engine, but I guess it just makes life easier. Especially for me, a person who don't know crap but would like to read about these things.
P.S.
Why does the 350Z and the G35 coupe look so much alike? Arn't they going after the same market? with about the same price, with the "same" (used loosly) skyline inheritance?
Old May 27, 2002 | 08:45 PM
eric93SE's Avatar
P.S.
Your right Afro, there are quite a few people on the org that have good info on there web page. I like putting up this info on the org so that others can refer to this stuff and understand what goes wrong in the max and what can be done about it. Right now I'm concerned with getting my max in peak condition so I can get this much awaited dyno work with Unorthodox Racing and the prototype UDP results. I want this pulley to make more power than the competitors pulley (purely for bragging rights ). I think the competition (ASP) claims there pulley makes 8hp, so I'm aiming for 10-12hp on my motor (mostly stock). I'd like to get to the track and see what kind of 1/4 mile times I can achieve with the new pulley, most say somewhere between 3-4 tenths or something. I dont know If I'll have time to get to the track before or not.
And the 350Z (nissan), and the G35 (infinity), Since they are really the same make there will be a lot of common similarities. But unfortunatley stying should not be one of them.
Old Jun 1, 2002 | 07:56 AM
wojtekj's Avatar
Is the KS on the top of the engine next to the fuel rail?
If not please explain the exact location of the connector, thanks.
Old Jun 1, 2002 | 09:28 AM
Matt93SE's Avatar
STFU n00b!
Congrats, Eric.. You made the first new sticky.
I'll at least stick it at the top of the page for a while, and when I get time I'll archive them all into one post and then "unstick" them so they don't sit at the top of the screen and take up the first two pages like the other forums.
But anyway, good work. I'll take a look at mine this afternoon. my car's really been sucking ***** on the low end. once I hit about 3000 rpm, you can hear the tone of the engine change and the thing just PULLS. and it's not VTC of the power valve. something else, and it's been getting worse as the weather warms up. sounds like a knock sensor/octane problem to me.
Old Jun 2, 2002 | 06:44 AM
RosenKen's Avatar
I too will be replacing my knock sensor in the next couple weeks for my low end is getting more and more unacceptable. It got better when I increased my timing after replacing my VTC's and all, but it's about back to where it was, which leads me to believe the knock sensor is corroded/bad. Good info on reusing the old intake gaskets, I bought news ones when I took the head off (I think they were $50 for the two from Courtesy) so mine should still be decent.
Old Jun 2, 2002 | 07:55 AM
MaDMaX024's Avatar
KS+headwork questions
if i were to get far enough to clean the connectors on the knock sensor, how hard would it be to replace it? i'm thinking if i test it and its bad to just replace it then..of course, this'll be all around the time i'm getting new VTC and having my heads rebuilt..now just for an FSM.
also, if i were to replace the valve springs with those from a 300zx (new, not used), would i see a benefit? i mean, when i get an ECU, would i be able to rev higher, safely?
Old Jun 3, 2002 | 10:10 PM
JonnyMax's Avatar
The 300zx Valve springs fit?
If so then I need to add that to my list.... TT or NA springs?
Old Jun 4, 2002 | 11:10 AM
MaDMaX024's Avatar
Re: The 300zx Valve springs fit?
TT and NA springs are the same according some faq my friend read (in doing research on na-->TT conversion). i'm also wondering if they'll fit and work properly..
Old Jun 5, 2002 | 07:50 AM
Matt93SE's Avatar
STFU n00b!
you should be able to find the information on the valve springs from your local dealer if they're willing to spend a few minutes of research on the computer.
also, why would you want to change valve springs? the VE and VG30DE both have about the same red line and rev limiter..
and please start another thread if you wish to continue discussing this. this thread was originally about the knock sensor, not valve springs.
Old Oct 11, 2004 | 01:49 PM
fdaza's Avatar
Where is the knock sensor located
I am having hard time starting my 89 maxima in the mornings. Seems like there in no current going to the spark plugs, could this be a problem with the knock sensor????
Old Oct 11, 2004 | 02:57 PM
Mizeree_X's Avatar
Getting back to his roots
Holy old post, Batman. The knock sensor sluggishness is primarily a VE problem. And the symptoms you describe don't have anything to do with the knock sensor.
Old Mar 21, 2007 | 01:41 PM
concordmike's Avatar
I just pulled my codes from the computer and I got a 34. According to my repair manual it is a knock sensor. I have already ordered a new one from EBAY.(saved 100$ off dealer price.)
My question is, Could a knock sensor cause the engine to backfire and knock, When It warms up my Maxima drives bad, very low on power and surges/backfires. or is that somthing else. I pulled my spark plugs and the 3 that came out of the rear bank had white insulators while the three out of the front bank had the standard off white/tan color. According to what I have read this could mean lean fule condition or spark knock.
So then I might need to replace the rear bank of injectors. ?? and the knock sensor.
Has anyone else experienced this type of problem from just a bad knock sensor.
I have already replaced the gas filter and checked the air filter. I also did a compression test. I got 175PSI in all cylinders +/- 2 PSI with a cold engine.
any help appreciated.
thanks guys.
93 SE
Old Mar 21, 2007 | 01:59 PM
DanNY's Avatar
Ad·min·is·tra·tor
thanks guys.
93 SE
sounds like a lean condition that's causing the engine to knock hence the knock sensor code.
definitely check the injectors and the harness...but don't be so quick to yank out the knock sensor just yet.
Old Mar 21, 2007 | 02:16 PM
Matt93SE's Avatar
STFU n00b!
But also keep in mind that if it's backfiring, that means there's fuel inside your exhaust that's burning after the fact. which means you're running rich possibly.
check ignition timing as well as the knock sensor.
what fuel are you running?
cleaned injectors lately?
Old Mar 21, 2007 | 02:17 PM
Greeny's Avatar
¯\(°_o)/¯
93 SE
A bad knock sensor usually will not cause backfiring,when the knock sensor fails,the ecu will automaticly retards timing to the extreme until you replace the sensor,you could bypass the ecu failsafe with 470k ohm resistor in the harness plug going to the sensor,but you Absolutely must run PREMIUM FUEL until the sensor is replaced..It is very difficult to get to the sensor[labor wise],it is under the intake plenum/injector rail/coolant pipe,in the valley between the cylinder heads..
The backfiring/stumbling issue may be a bad coolant temp sensor and/or one of the coils may be failing..
Also,a stuck open fuel injector could cause a backfiring issue...
Old Mar 21, 2007 | 04:24 PM
xx-Marshall-xx's Avatar
kthxbye2u
KS is a pretty IN-DEPTH job
like greeny said
along with your KS you ordered, i would advise you to get a SUB harness connector along with it
Old Mar 21, 2007 | 06:27 PM
I read in another thread that the injectors used on my motor do not respond well to cleaner/ additives ect. I dont know if this is true. Somthing about a non pintle design.
I will pick up a coolant temp sensor tonight and screw it in there. Does anyone know how many ohms of resistance the injectors are supposed to have. I have a DMM I can test them with.
Old Mar 21, 2007 | 06:33 PM
Greeny's Avatar
¯\(°_o)/¯
The injectors should ohm out between 11-14 ohms...
Old Mar 21, 2007 | 08:40 PM
Alex_V
Also when you go to refill the coolant make sure you bleed the coolant system properly. Just use the free search at the top of the forum its been posted alot.
~Alex
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
maxinout93
Aug 20, 2015 02:17 AM
kenc15
Aug 5, 2015 08:29 AM
