I was frightened
Old May 28, 2002 | 05:24 PM
hclll's Avatar
I was frightened
Today I cleaned the throttle body with a bottle of carborator. I also removed and cleaned the front of the sensor which has the idle speed adjusting screw on it.
But when I took it to a test drive, some smoke came out of the hood. And I found out the coolant begins to leak fast from a hose.
What could cause this? What should I do now? Did I put the sensor back in a wrong way? I noticed it has a hexagon tip.
THanks.
Old May 28, 2002 | 07:13 PM
FrankBattle's Avatar
Re: I was frightened
THanks.
You put a hole in something = coolant leak
cleaning solvent is burning off = smoke
Just a guess. There is almost no way to tell you the problem over the web. Next time, use a real throttle body cleaner.
Old May 28, 2002 | 07:23 PM
ThurzNite's Avatar
Re: Re: I was frightened
I've never seen that at the local kragen. who makes it?
Jae
Old May 28, 2002 | 08:04 PM
«§»Craig B«§»'s Avatar
Re: Re: Re: I was frightened
Jae
I've seen several brands at PepBoys, the stuff I used was called "air intake cleaner"
Old May 28, 2002 | 09:13 PM
Pickwick's Avatar
Re: Re: Re: Re: I was frightened
Does the three step intake cleaner that they do at Valvoline include a throttle body cleaner?
