Throttle body cleaning question
Old May 29, 2002 | 03:55 PM
KingKong8247's Avatar
Hey I was planning on cleaning my throttle body today so I went to pep boys but I couldnt find any throttle body or intake cleaner so I asked this biker dude what he thought I should use and he told to buy Gumout Carb and Choke Cleaner and I was wondering if that stuff will work or should I just go somewhere else. Thanks
Old May 29, 2002 | 04:08 PM
davis4005's Avatar
When I did mine it was called throttle body and carb cleaner, I found it at Napa.
Old May 29, 2002 | 04:17 PM
pearl93max's Avatar
I used the same stuff from NAPA...worked good
Old May 29, 2002 | 04:46 PM
Sudesh's Avatar
Just like 2 days ago someone posted a message because they're having problems with their car after they cleaned the intake with carburator cleaner. I don't know if there is a difference between the two but you should use the throttle body cleaner just to be safe. I don't think they would be two different products if they're the same thing.
Pepboys carries it, if you can't see if ask someone at the counter. There are a number of different companies that make it..GUNK, STP, Strauss has their own brand.
Old May 29, 2002 | 07:09 PM
FrankBattle's Avatar
Go to Autozone or the like. The one I got and used is called "Throttle Body & Air Intake Cleaner" by STP.
Old May 29, 2002 | 07:17 PM
superdesi's Avatar
GUMOUT makes an "Air Intake & Throttle Body Cleaner".
Whatever brand you choose, just remember one thing, most throttle bodies have protective coatings. Buy something that is safe for it.
Old May 29, 2002 | 07:36 PM
MaxManMo420's Avatar
use throttle body cleaner the other stuff has something in it and it will be harder to start your car!!!
Old May 29, 2002 | 07:41 PM
Hey thanks for the help Good thing I asked before I used that stuff
Old May 29, 2002 | 10:32 PM
mykizism's Avatar
Daaaanng all you guys need to stop spending so much money on intake cleaner.
run to the dollar store and pick some up for only a dollar a can
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
