Odd Ticking
Old Jun 2, 2002 | 05:29 PM
PATRICK94SE's Avatar
Odd Ticking
OK FIRST PERSON TO SAY VTC GETS A BEAT DOWN
Alright I will try to describe this the best I can.... Today I was driving around for about an hour then pulled into a parking lot. I put the car (5 spd.) in neutral and set the E-brake. I then noticed a loud (maybe three-four ticks per second) Ticking. Normaly I would write this off as insignificant however the ticking would go away if I pushed down the clutch pedal. Any input?
Old Jun 2, 2002 | 06:03 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Odd Ticking
VTC...j/k
I remember mtcookson or someone post that he was having this problem and it wound up being the "some bearings inside the casing that are bad" here is the link of his message...sorry I don't have a 5 speed so thats all the help I can be.
Old Jun 2, 2002 | 07:16 PM
Hmm his link to the sound did not work for me. Thanks for the reply though. It is not grinding at all though
Old Jun 2, 2002 | 07:54 PM
jp91se's Avatar
it's the VTC!!
I'm the second person
Old Jun 2, 2002 | 08:01 PM
STFU VG boy I am not two far away from you. I'll have a caravan of VEs on yo ***
Old Jun 2, 2002 | 08:18 PM
jp91se's Avatar
not if you can't see me! muahahahaha!
Old Jun 2, 2002 | 08:20 PM
Alright Alright this is a serious thread! I am still taking sugestions
Old Jun 3, 2002 | 06:42 PM
Anybody?
Old Jun 4, 2002 | 01:14 AM
blackandwhite's Avatar
To them I'm like an idol
Anybody?
Lifters? Check your oil level. Mine tick when oil is low.
Old Jun 4, 2002 | 06:10 AM
No I check the oil almost daily, I dont think the lifters would stop ticking when I push in the clutch pedal
Old Jun 4, 2002 | 06:55 AM
time2reup's Avatar
Where is the sound coming from? My lifters are sticking, but you can obviously tell its coming right from the valve cover...Does the sound come from the tranny, or are you just assuming it is related because it stops when you push in the clutch?
Old Jun 4, 2002 | 07:26 AM
Tranny Fluid?
Sorry, I missed the clutch pedal thing. I had an issue like this too though. Have you checked your gear oil? (Manual tranny fluid). I had a ticking sound like that except for when the clutch was in, then as more fluid went out, it became a loud clanking noise as opposed to a clicking noise.
A tranny shop tried to convince me that it was the throw-out bearing, but they failed to mention that there was no gear oil in it, and when I got it filled, it went away.
Old Jun 4, 2002 | 01:02 PM
I did not think of gear oil. I will look into that, Thanks
Old Jun 4, 2002 | 04:02 PM
battleminnow's Avatar
Re: Re: Odd Ticking
Originally posted by awsm66
VTC...j/k
I think we have a winner....
Really though, this sounds exactly like what you are describing.
Pete
Old Jun 4, 2002 | 04:38 PM
Hmm well not realy, the only thing simular is the fact that the noise only happens when in neutral.
Old Jun 5, 2002 | 09:30 AM
And that the noise goes away with the clutch in. I would look into bearings, not much outside the transmission interacts with the clutch when in neutral. IMHO
Pete
Old Jun 5, 2002 | 12:26 PM
CandiMan's Avatar
Say Candyman 5 times
Re: Odd Ticking
Originally posted by PATRICK94SE OK FIRST PERSON TO SAY VTC GETS A BEAT DOWN Alright I will try to describe this the best I can.... Today I was driving around for about an hour then pulled into a parking lot. I put the car (5 spd.) in neutral and set the E-brake. I then noticed a loud (maybe three-four ticks per second) Ticking. Normaly I would write this off as insignificant however the ticking would go away if I pushed down the clutch pedal. Any input?
As much as you don't want to hear it, but I don't think bad bearing in a tranny would make a clicking noise, bad bearing would be more like a grinding noise depending on clutch pedal position. Unless you don't change your oil regularly (which I know you do) and have excessively dirty oil which can reduce the oil supply to the lifters causing them to collapse I doubt it's the lifters. Trust me, when my VTC started clicking I was like WFT just like yourself. Before the clicking got worst I ran out and did a motor flush hoping this might help and it didn't. But as the weeks went by and the clicking started becoming more frequent I finally had to give in a accept the fact. Honestly it's not a pleasant sound when they are clicking constanly with a hot or cold engine. I drove about 10-12K before I finally gave in a did something about it, what a wonderful day that was
Old Jun 6, 2002 | 05:56 PM
BoyGenius84's Avatar
Sounds to me like its the input shaft bearings inside the transmission. I have overhauled a few hundred (I work for Nissan) and the bearings will rattle when its in neutral. Might wanna have it checked out.
Old Jun 6, 2002 | 06:41 PM
Well the ticking is gone. I had been driving realy hard right before I noticed it. Oh well
KabirUTA13
19
Oct 17, 2015 02:15 AM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
ColdCananda
Sep 20, 2015 10:45 PM
lrb6805
Sep 17, 2015 04:49 PM
