Can not shift to DRIVE
Old Jun 12, 2002 | 04:54 PM
Suya's Avatar
Don't know what happened to my car. I started the car and press the breck and try to put the gear into drive. The gear (automatic) won't move at all. The thing is that the little butten which I have to press inorder to shift the gear won't go down.
Any body has any idea what to look for. Thanks.
Old Jun 12, 2002 | 04:59 PM
Sudesh's Avatar
Re: Can not shift to DRIVE
Have someone press the brakes, if the brake lights don't come on check your "Brake Light" fuse. If your fuse is bad I'd suggest you find the root of the problem than just replacing the fuse.
Good luck.
Old Jun 12, 2002 | 05:09 PM
darrick's Avatar
Dallas Nissan Enthusiast
i have this same problem
I was told to check the brake pedel for some kind of switch that gos out hope this helps
Old Jun 12, 2002 | 06:37 PM
Suya's Avatar
Re: Re: Can not shift to DRIVE
Good luck.
I checked the brakes light. They are working fine. I think there is something else which is holding on to the shifter.
Old Jun 12, 2002 | 06:39 PM
Suya's Avatar
Re: i have this same problem
That is possible. Do you remember where the switch is located?
Old Jun 12, 2002 | 07:13 PM
darrick's Avatar
i have never checked
but it is somewhere on the rod that holds the brake pedal,oh yea just remembered there is also a fuse that gos to that also check all the fuses
Old Jun 12, 2002 | 07:16 PM
Sudesh's Avatar
Re: i have never checked
When you press the brake to shift into drive, do you hear a click?
Old Jun 13, 2002 | 05:32 AM
Suya's Avatar
Re: Re: i have never checked
No I don not hear the click sound. I know that before I have this problem, there used to be a click sound when I press the breck.
Old Jun 13, 2002 | 02:52 PM
matt1sd's Avatar
Re: Re: Re: i have never checked
not to change the subject, but i hate that stupid little release button in front of the shift lever. there is no point for it. and when you have you hands full, its a biatch to try and shift it w/1 hand. but i think ive mastered that skill. but it would be a lot easier to not have it. i tried to see if i could take it out, but that would be super complicated. oh well, another one of the very few 3rd gen flaws...
Old Jun 13, 2002 | 04:03 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: Re: i have never checked
What I did on my GXE was take the bracket that has the lock on it and bend it out of the way. It is not the best thing to do if you have a child or something because there is no safety feature at all now because you can pull it out of part without the foot on the brake or using the little button. I did that when my little girl was just a baby but now that she is older I am going to fix it the right way this weekend.
Old Jun 14, 2002 | 02:35 PM
Suya's Avatar
My problem got fixed
There was a small pin like button at the buttom of my gear shifter. I pressed that one and I was able shift the gear from Park to Drive. After that it was fixed by itself. Now I do not have any problem changing the gear.
Old Jun 14, 2002 | 03:08 PM
lateralus's Avatar
Had same problem.....fixed
There is a brake/shift lock button that has its own fuse. Your rear-lamps probably have a short(eventhough your brake-on lights work fine). The fact that this short occurs, screws with your brake/shift lock and might cause dimming or failure of internal lights and dash lights. Changing the fuses for my rear-lamps was just a temporary fix that would last anywhere from 1 minute to 3 days. Mechanic had to replace the terminal holding my rear lamp-light (charged $20?!?) and everything has been fine since (6 weeks). Again, my rear lights would not work at all, but the brake lights would activate.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
Maxie40
Sep 14, 2015 11:28 AM
