worth fixing speedometer? check this out
Old Jun 13, 2002 | 07:06 AM
NixMaxGLE's Avatar
i figured out that more than likely, the jerkiness w/ my car's shifting lately is due to not only the addition of the intake, but also the fact that the speed sensor in my speedometer is broken, so (as the mechanic explained it) the transmission doesn't really 'know' how fast the car is going, and therefore is unable to shift smoothly and whatnot. while the guy didnt guarantee that fixing the speedometer will in turn fix the jerky shifting, he did say that however i look at it, the speedometer/odometer sensor is the next thing i need repaired if i want to fix other problems. my situation is this: the sensor part alone is about $125-150, and then whatever it would cost to get it all put in (he told me no more than 200 bucks total). should i go ahead and do this? obviously, not having a speedometer sucks in its own right, since i get even more nervous when i see cops and everything, and the jerkiness of my cars shifting is really annoying, and probably not all too good for the car. would you fix this if it happened to your car anyone? just looking for some input... thanks for your time
NICK
Old Jun 13, 2002 | 07:15 AM
male's Avatar
Re: worth fixing speedometer? check this out
Depending on how bad it's jerking, this could really cause major damage to everything up front..suspension joints, axles, motor mounts..MANIFOLD STUDS, you name it. Fix it soon or suffer heavier (more $$$) damage in the future. The way I see it, the only options are fix it or sell it! For 200-300, I'd fix it. Did you swap the old airbox in to see if it corrected? I seem to remember you saying you did. The CAI really shouldn't cause ANY running probs, unless it isn't installed properly (leaking air past the mass air meter), that's the only way it could F*** things up. Good luck.
---Mike
Old Jun 13, 2002 | 07:37 AM
Terry28's Avatar
well i would fix it instead of creating bigger problem which might cost more see i have an engine mount broken but i am fixing it for 150 so it won't mess up the car at least. so if it was me i would fix it.. Maxima rocks!!
Old Jun 13, 2002 | 02:30 PM
drsprite's Avatar
Terry loves putting those 3 faces at the end of every post she/he makes... hehe
Old Jun 13, 2002 | 04:12 PM
Terry28's Avatar
i am a he and are those three faces bothering you??
Old Jun 13, 2002 | 05:08 PM
drsprite's Avatar
nope, just find it funny
Old Jun 13, 2002 | 05:28 PM
Terry28's Avatar
how??
Old Jun 13, 2002 | 05:31 PM
drsprite's Avatar
how??
because you don't forget to do it? sorry bro.
Old Jun 13, 2002 | 05:35 PM
Terry28's Avatar
well i don't... k whatever makes you happy and i used to write Maxima rocks but it was annnoying so i stopped doing that.. and if this faces are bothering someone i can stop doing them too..
Old Jun 13, 2002 | 05:41 PM
drsprite's Avatar
heh, I never said it bothered me, did I?
Old Jun 13, 2002 | 06:01 PM
Terry28's Avatar
no u didn't so thats ok..
MR2 T'd
Jul 9, 2021 05:06 AM
9aj9
Apr 5, 2020 12:11 AM
iflexsteel
Sep 2, 2015 08:04 AM
