rear brake replacement
Old Jun 15, 2002 | 07:00 AM
maxi baby's Avatar
Can someone direct me to a site, or post instructions on replacing the back brakes. my main concern is taking the emergency brake cable off and putting it back on. Any tips??
Old Jun 15, 2002 | 08:36 AM
superdesi's Avatar
Just take the pin bolts out and it should be simple for ya then. What pads are you putting in?
Old Jun 15, 2002 | 09:22 AM
dnas420's Avatar
yo
ive got some brand new genuine nissan brake pads for sale. 35 shipped. stock headlights, and fogs. let me know if you want anything.
Old Jun 15, 2002 | 10:05 AM
«§»Craig B«§»'s Avatar
Re: rear brake replacement
what are you replacing?
if it's just the pads (I see you have a SE, so it's disc brakes all around), then you dont need to worry about the parking brake cable
when you compress the piston to slide the caliper back down, be sure to use some needle-nose pliers to twist it clockwise while pushing in; dont just use a clamp like the fronts
for pads, you just need to take off the wheel, remove one bolt holding the inner caliper to the outer portion and the flip the inner caliper assembly up and you can then get to the brake pads
for rotors, you need to take off both the inner and outer caliper and then the rotor will just pull off with some force
in this pic, the silver part is the part I'm calling the "inner caliper" and the black is the outer
yours will be all one color (brake dust grey) unless you've painted them like this guy (killermove is his name)
where in GA are you? I'm in Duluth (Gwinnett County) if you know where that is
Old Jun 15, 2002 | 06:12 PM
kingrye's Avatar
i got se and and i got drumms can i put on dics in the rear easy
Old Jun 15, 2002 | 07:57 PM
Michael's Avatar
Back in a 3rd Gen.
That makes no sense what so ever. If you have an SE you have rear disks. If you have a GXE you can convert it to disks...do a search because Matt(I think it was him) posted a link on how to do the conversion.
Old Jun 15, 2002 | 08:05 PM
dnas420's Avatar
so no takers?
i need to sell these fogs, stock headlights, and rear brake pads. anyone????
Old Jun 15, 2002 | 08:27 PM
kingrye's Avatar
i have a 91 se with rear drumm breaks
Old Jun 15, 2002 | 08:40 PM
Michael's Avatar
Back in a 3rd Gen.
First one I have ever heard of...are you sure they are drum brakes? If they are drum are you sure you have an SE?
Not that I dont believe you but I have never heard of an SE without disk brakes...I thought that was one of the standard features of the SE from 89-94.
Old Jun 15, 2002 | 09:18 PM
noleafclover's Avatar
that ad seems to be advertising a 89-91 SE with all disk brakes...and i don't think they would have changed it for the 92 so...hmm maybe someone did a disc to drum conversion
Old Jun 15, 2002 | 09:34 PM
DanNY's Avatar
Ad·min·is·tra·tor
if you have drums..then you have a GXE.
disk brake pads goes on disk brakes.
brake shoes goes on drum brakes...
they don't mix and match.
Old Jun 16, 2002 | 11:07 AM
Z's Avatar
Z
Re: Re: rear brake replacement
Hey Craig, are you going to make it out to the stone mountain meet?
Old Jun 16, 2002 | 02:07 PM
Re: Re: Re: rear brake replacement
not sure yet, but probably will
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
