No Reverse
Old Jun 18, 2002 | 05:34 PM
imported_black's Avatar
No Reverse
HELP!!! my 91 maxima/automatic car does not move in the R gear. it engages but does not move at all. it drives me home but in second gear. does this mean i have to get r/1 gear replaced. or is there something major to be fix with the tranny. i can't seem to get the ecu codes decoded too. help help help pls pls pls THANKS IN ADVANCE.
Old Jun 18, 2002 | 05:37 PM
pearl93max's Avatar
someone's about to spend some money!!!
Not saying it's funny, but you'll need to rplace the tranny and it's not cheap.
Old Jun 18, 2002 | 07:02 PM
davis4005's Avatar
Yeah, sounds like your tranny is nearly shot. Start looking for a good place to get it done at and diagnosed. Reverse is usually the fist gear to go. Is there any abnormalties when driving forward, such as slipping, hunting for gears, missed shifts, slipping inbetween shifts?
Old Jun 18, 2002 | 07:16 PM
Sudesh's Avatar
Your transmission is obviously on the way to death. You can't do anything to save it so don't even try to buy those additives.
You should stop driving the car. The next thing that will happen is that you'll get stuck somewhere and have to get it towed.
look into getting it rebuilt. If you really cant afford a rebuild, you can replace it with a used tranny. If you just replace it you're bound to have the same problems sooner or later. The time around after you get it fixed, add on a transmission cooler.
Old Jun 18, 2002 | 08:36 PM
davis4005's Avatar
Yes do not use additives. I added some Slick 50 High Mileage honey in my tranny when I could tell it was going, and I think it ended up speeding up the breakdown of the transmission.
James92SE
142
Jan 2, 2024 09:23 AM
dcam0326
Sep 18, 2015 04:52 PM
Lilfatz301
Sep 18, 2015 08:06 AM
lrb6805
Sep 17, 2015 04:49 PM
