it makes no sense
it makes no sense
left side lowbeam out, ok no big deal. i get new bulb but low beam is still out and hi beam works. i check the fuses and they are all fine. i check the plug connector with a volt meter and the voltage in each of the three prongs equal with the right side which works. ok, the bulb works( i tried it on the right) the bulb is getting proper voltage, the prongs arent bent as far is i can tell. fuses fine, WHAT THE HELL!
Connector is getting voltage but have you tried hooking the voltmeter to the plug where the bulb socket is? ie.. w/ the harness connector connected but w/ no bulb. Check if voltage is getting into the bulb socket.
people this is no joke
i know it sounds impossible but im not kidding around. my insections due in july and i don't have the money to take my car in for a firkin headlight (i have to pay my bill to get smarter this fall) and this has stumped my mechanic friends anyway. please help a brotha out!
Originally posted by sublunary
thats what i did. i checked each prong in the socket. there are three. one power and low and hi beams i assume. all voltages the same as the right side which works fine. it blows my mind
Mar 12, 2020 12:06 AM
