Shifting Question
Old Jul 4, 2002 | 08:42 PM
rustangkilla
Shifting Question
So my question is, does it hurt any part of the car to do a 2nd gear to 1st gear downshift and floor it at about 25mph? I'm thinking it might not be too good for the clutch. Opinions?
Old Jul 4, 2002 | 09:55 PM
NCSUmax's Avatar
Re: Shifting Question
I'm gonna have to ask you why you would want to do that?
Old Jul 4, 2002 | 11:21 PM
Maxima_Van_WA's Avatar
If you match the rev's AND double clutch it should be fine. But once again--- WHY??
Old Jul 5, 2002 | 01:34 PM
Nissan-R's Avatar
Shifting question
Would you burn yourself?????
Old Jul 5, 2002 | 02:35 PM
nardo'89SE's Avatar
syncros will wear out, and that is money to replace
Old Jul 5, 2002 | 03:10 PM
rustangkilla
in response to why?:
sometimes you will just be cruisin' at a lazy 25mph and want to "kick it in the ***" real quick and downshifting obviously will accomplish this.
Old Jul 5, 2002 | 04:27 PM
Dummy's Avatar
this isnt the 50's
Old Jul 5, 2002 | 04:45 PM
By the time you downshift correctly, get on it, then upshift to 2nd agin you should have stayed in second doin 25 MPH.
As to why to double clutch since this isn't the 50's?? It helps reduce the wear on your synchros since letting the clutch out after matching the rev will bring your shafts up to speed instead of the syncros having to do the work. It basic power transmission!
Old Jul 5, 2002 | 07:15 PM
sabotosh's Avatar
can 1st go much beyond 25 anyway? it does seem like a waste of time to go 2-1-2 again, and by 25 2nd is in a fairly good spot as far as power goes... it's probably unneeded wear on your tranny and people look at you funny too when you're turning 6000rpm and going 25mph
Old Jul 5, 2002 | 11:45 PM
MrGone's Avatar
well in my VE Auto, first goes to almost 40mph, second goes to 80, 3rd, havent gotten there yet.
i love me max
MrGone
Old Jul 7, 2002 | 02:14 AM
Dummy's Avatar
i love me max
MrGone
thats because you have a 4spd, not a 5spd.
Old Jul 7, 2002 | 02:18 AM
MrGone's Avatar
i know
MrGone
Old Jul 8, 2002 | 12:58 AM
pmb1985's Avatar
whats double clutching ?
Old Jul 8, 2002 | 07:18 AM
Double clutchingis when you push in the clutch, take it out of gear, into neutral, let the clutch out, push it in again, and put it into the next gear. What this does while letting out the clutch in neutral, is let the shafts in your transmission get up to speed with the input shaft, helping lessen the wear on the
Mar 12, 2020 12:06 AM
2kmaximel
Nov 29, 2015 01:51 AM
Cotozic
Sep 23, 2015 11:55 PM
