WTB - passenger 4th gen caliper and both rear rotors
May 13, 2007 | 01:44 PM
I am looking for a rear caliper system for my 97 maxima on the passenger side. Also a set of new rotors for the rear. My passenger side is dragging and the rotor is seized. Can anyone help? Thanks: e3
May 13, 2007 | 02:21 PM
Quote: I am looking for a rear caliper system for my 97 maxima on the passenger side. Also a set of new rotors for the rear. My passenger side is dragging and the rotor is seized. Can anyone help? Thanks: e3
I may have the caliper i will check.
May 13, 2007 | 02:34 PM
Can you also check for the rotors? I would like to be able to have some cut and ready for install when I take the rears apart. Basically take out the old ones and install the new cut ones with the caliper.
Also, any good tricks to compress the rear calipers to get the new assemblies in?
May 13, 2007 | 02:37 PM
Quote: Can you also check for the rotors? I would like to be able to have some cut and ready for install when I take the rears apart. Basically take out the old ones and install the new cut ones with the caliper.
Your better off buying new rotors. There cheap. By the time you buy a used set and have them turned it will be the same price as new ones. The caliper has to be turned back in.
