FS: 96 VLSD 5speed transmission w/ deburred-detailed-cryo'd 3rd gear freshly rebuilt
Old Jun 19, 2007 | 09:18 PM
Nealoc187's Avatar
SLOW
For sale is a 1996 VLSD 5spd transmission. This transmission is freshly rebuilt, just finished it tonight 6-19-07. Items worth mentioning for this trans are:
- Detailed/deburred and cryo treated 2001 (5th gen) 3rd gear - I am NOT promising that this gear is indestructible and I make no warranties but this is the work I had done when I was building up my 2001 AE LSD trans (this is the 3rd gear out of that trans).
- Mild detail and polishing work done on shift components to improve shift quality
- Minor oil mods to improve oil flow to input shaft bearing
- new 2nd gear synchro
- New differential carrier bearings
- New input shaft front bearing
- good main shaft bearing
- all bearings properly shimmed to the following specs:
- Input: 1.34-1.39mm shim required - 1.37mm shim used
- Main: 1.08-1.13mm shim req'd - 1.11mm shim used
- Differential: 1.35-1.40mm shim req'd - 1.36mm shim used
- Glass beaded transmission case - so clean and pretty you could eat off of it
I'm trying to think if there is anything else unique or worth mentioning about this trans - can't think of anything right now. I'll update the post if I think of anything.
Price is $1100 SHIPPED - I will ship it via Fedex through work.
Old Jun 21, 2007 | 12:40 PM
Fearfox's Avatar
You got pm
Old Jun 21, 2007 | 09:44 PM
sergofast's Avatar
man i wish i knew you were going to be selling this before i got my vlsd! crap
Old Jun 22, 2007 | 06:46 AM
eckounltd287's Avatar
Likes them corn fed
do we need to get vlsd axles in order for this to work?
do we also need to add a button for whether we want the lsd on or off?
Old Jun 22, 2007 | 07:01 AM
jaemax's Avatar
^^^^ you will need the LSD drivers side axel... as for the option of turning it on and off with the flick of a switch.. I cannot confirm.... Either way, a good deal!
BUMP for a very well built tranny and price!
Old Jun 22, 2007 | 07:13 AM
nismos14's Avatar
§è~® f®ÈÄk
Ya man you need a switch for it.
Old Jun 22, 2007 | 02:25 PM
Nealoc187's Avatar
SLOW
VLSD works all the time. it is purely mechanical there is nothing to switch. VLSD driver's side axle is needed for a VLSD trans.
This trans has been sold. I will have more transmissions for sale in coming weeks. keep checking this forum or my sig if you're interested.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
zmcneely13
Sep 26, 2015 02:26 PM
