F/S Very complete v2 kit with v1 conversion
Old Aug 6, 2007 | 07:42 PM
DanIAm's Avatar
Up for sale is my full set up with lots of extra parts. Just put most of these parts together but recently blew up my daily driver so need to raise some money for a replacement.
The original v2 kit was on a friends car for less then a year and my set up with mattys conversion was on my max for about 2 weeks or so. Only drove it about 15 miles while on my car. In the short time it was on my car I had 0 belt issues or clearance problems in regards to the belt. You can also hear this setup in the video on my cardomain with the vortech BOV.
The v2 plate does need a new idler pulley. This kit did shread belts while using the v2 plate but mostly due to bad pulleys on the car, cant really contribute it all to the plate itself.
Im doing this as a full kit to eliminate having to break it all up myself to sell the extra parts. I'll have a complete updated parts list along with pictures of it off the car this weekend (8/12)
The Parts
V2 Head Unit - serial# 37716
OLD Blower to Plate Screws
New Blower to Plate Screws
New plate to engine screws/washers
4060-705 Gatorback belt
Drain Back hose (NEW)
Drain back plate
pre-cut Drain Back Hose
Stock drain back plate
3.33" 6 Rib Pully
Vortech FMU
Stillen V2 Charge Pipe
3 Inch Charge Pipe with vortech flange
UNUSED Stillen SC Badge, little scratched but unused
Vortec race Blow Off Valve
V2 Oil Line
Thermostat housing w/ thermostat
T-Rex Fuel Pump (pump only, no wiring for it)
Rubber V2 90 Degree coupler
Upper part of charge pipe w/ Methonal Jet (capped off in picture)
K&N Filter RA-0980
8 3.25' T-Bolt Clamps
Misc other clamps
2 3" straight couplers red
2 45 Degree couplers Red
2 Chopped 3" 90's - probably not useable
4 Misc Cupplers
Step down rubber adapter from 2.75 to 3"
V-2 Bracket w/ Plastic Pully
Extra plastic pulley (Fenner Drive)
V-2 Tensioner Bracket
Stock Tensioner (with out pulley)
V-2 Oil T
Matty's V-1 Bracket
6 NGK Spark PLugs BKRGE-11
9ft 3/8th inch Tranny Line (400psi for steering lines)
Injen upper Cold air Intake (just had it laying around)
misc vacuum t's
misc vacuum caps
misc brass fittings
Pre cut radiator hose
extra pieces of vacuum line
fuel lines to run the fmu with adapter to conect fuel line to stock line
Permtech Hi-Temp Thread Sealant - small tube
Permatech black gasket sealant - small tube
TurboSmart Blow off valve (not pictured in pictures)
autometer boost gauge #4301
autometer volt meter #4391
oil preasure guage #4327 - Sender never installed in vehicle.
Tripple Gauge pod sprayed Tan
some things you'll need to put this on your car
a new 90 degree coupler from blower to charge pipe if using the 3" piping.
MAF adapter from frankencar or ebay
The preasure switch to make the trex pump work, I have trex pump only with out the wiring or just use a walboro pump
a step down coupler to hold the filter onto the blower
1 2.75 to 3" rubber adapter for the throttle body unless using stock V2 charge pipe.
Thermostat gasket
Maybe some extra vacuum line if theres not enough in the lengths you need
radiator hose to relocate resevoir
Thats really it that i can think of, but be sure to do some research before installing it. The parts listed are the result of a lot of research on my part to do it the right way. This is a pretty good deal considering the extra parts included.
Really havent seen anything come up lately so not really sure what a complete setup would go for.
Im going to start at $3500 for everything. PM me with offers. I can ship this anywhere in the continental US. I would prefer money order as payment to avoid paypal fees. But paypal is doable, fees will just have to be takin into consideration. As for shipping it really just depends on where you are and how many boxes it takes to get it to you. I can also ship it all on a freight pallet, depending on where you live it may be cheaper.
Also keep in mind mattys out of v1 plates so if you want to get reliable boost b4 the end of the year this may be your only chance.
pictures and video can be seen here http://www.cardomain.com/ride/262488/6
A little bit about me for credibility reasons. For those that dont know me I manage ebay and soon to be eccomerce sales for Toms Foreign Auto Parts on eBay. Link to our ebay store here http://stores.ebay.com/Toms-Foreign-Auto-Parts (excuse the site redesign, couple of bugs to be worked out still) also my own ebay account is dpwaudio.
Let me know if you have any questions on anything Thanks
- Dan
*****EDIT*****
Updated list 8-15-07
Old Aug 6, 2007 | 08:13 PM
Nightkid08's Avatar
was this kit the reason that your engine failed?
Old Aug 6, 2007 | 08:33 PM
DanIAm's Avatar
Not at all. My engine went in 05, This kit was only on my car the last couple weeks. Max ran mint with it and still runs mint with out it. Right now for me, i've had this car for like 6+ years and I really rather put the money into a nice daily driver instead of any more into the max. I was driving a rusted 93 cherokee, broken seats, heat on one speed only. No AC. The brake lines just blew out on it and the engines been knockin for a while so its time for somthing newer and nicer with some options. If it wasnt for needing somthin b4 winter this kit would still be on my car
Old Aug 6, 2007 | 10:23 PM
VIP Maxima
whoever decides to buy this, the v2 plate and tensioner bracket + charge pipe can be sold for a nice $800 to knock the price down to 2700 for a pretty much full kit. thats less than what it has costed me so far
Old Aug 8, 2007 | 12:30 AM
Mymax97's Avatar
Hi
im tempted but the v2 cant be rebuilt to t trim.
Old Aug 8, 2007 | 01:13 AM
VTMaxima's Avatar
I am very interested in this setup. You are less then 4 hours away from me, would you be willing to help me install? I could drive to CT and pay for the help of installing the sc. Also you woudn't have to deal with shipping. Let me know if that would be something you could do. Thanks, Tyler
Old Aug 8, 2007 | 06:23 AM
DanIAm's Avatar
PM Sent.....
Old Aug 14, 2007 | 08:44 AM
DanIAm's Avatar
Uploaded pics of the kit off the car
http://viewmorepics.myspace.com/inde...albumId=705205
Little easier to do them on myspace then cardomain, updated parts list will come later on tonight or tomorrow
- Dan
Old Aug 15, 2007 | 05:42 AM
DanIAm's Avatar
updated parts list, this is the complete list to go along with pics
Old Aug 27, 2007 | 03:56 AM
DanIAm's Avatar
bump....still for sale
Old Aug 27, 2007 | 05:52 AM
98MaXeDouT's Avatar
let me know if you're willing to part anything out....
Old Aug 27, 2007 | 06:02 AM
DanIAm's Avatar
Let me know what your looking for, Im going to give it another week or 2 and then i'll probably break it up
Old Aug 27, 2007 | 06:50 AM
98MaXeDouT's Avatar
You got a PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Luev
Sep 30, 2015 11:50 PM
Pied
Sep 26, 2015 03:29 PM
