FS: I30 Electric Gas Door Actuator/Switch
Old Nov 17, 2007 | 12:13 PM
99BlackMaxMS's Avatar
I have an I30 electric fuel door actuator and switch for all you 4th gen maxima guys. I have all the parts required to make the conversion.
$50 shipped
Let me know if you guys need a pic.
-Matt
Old Nov 17, 2007 | 08:38 PM
Blackwind's Avatar
PICS!!!!!!
Old Nov 18, 2007 | 10:14 AM
Old Nov 19, 2007 | 12:35 PM
Bump...pics added.
Old Nov 19, 2007 | 12:38 PM
Blackwind's Avatar
is that wire cut? easy install?
Old Nov 19, 2007 | 12:40 PM
Yeah basically you just tap into a 12V power source. I can find the writeup for you if you want it.
Old Nov 24, 2007 | 06:55 PM
ttt
Old Nov 26, 2007 | 11:38 AM
bump!
Old Nov 26, 2007 | 11:46 AM
Blackwind's Avatar
if this aint sold by friday ill get it.
Old Dec 1, 2007 | 11:49 AM
Still available......
Old Dec 3, 2007 | 11:55 AM
BUMP!
Old Dec 3, 2007 | 12:04 PM
gtr_rider's Avatar
192.168.1.1
I have a switch as well, no pigtail though..
Old Dec 4, 2007 | 04:50 PM
I can sell you the actuator for $40 shipped if you want.
Old Dec 9, 2007 | 08:50 PM
Bump!
Old Dec 12, 2007 | 01:50 PM
ttt
Old Dec 12, 2007 | 06:41 PM
gtr_rider's Avatar
192.168.1.1
no thanks, too minimal of a mod for me to care about really
Old Dec 13, 2007 | 01:44 PM
I just dont have the time or motivation to do it.....thanks anyways
ttt
Old Dec 17, 2007 | 02:12 PM
bump
Old Dec 17, 2007 | 05:26 PM
black_maxed95's Avatar
show me a write up and i could be interested
Old Dec 17, 2007 | 06:34 PM
https://maxima.org/shoptalk/sub_modi...t1/index.shtml
Old Dec 17, 2007 | 06:47 PM
link doesnt work
Old Dec 17, 2007 | 07:01 PM
Ill post it up in feedback to see if they can access it...
Old Dec 19, 2007 | 03:00 PM
Bump.....
Old Dec 22, 2007 | 06:04 PM
Bump it up!
Old Dec 27, 2007 | 12:34 PM
bump
Old Dec 27, 2007 | 10:11 PM
Blackwind's Avatar
i got your pm
Old Jan 2, 2008 | 03:02 PM
Bump it up!
Old Jan 2, 2008 | 10:47 PM
Blackwind's Avatar
i cant find the install instructions for it.
Old Jan 3, 2008 | 05:18 AM
They are in the stickies under I30 accessories installed on your Maxima which does not load after the site crashed in Sept. I asked for help in the feedback forum with no luck. I'll try PMing a mod now.
Old Jan 6, 2008 | 07:18 PM
The best i can do for offering help on install is to tell you what the guy who I got it from told me.
There are 2 wires, one is power one is ground. Wire it up, and you will need to find someone with an I30 to see where their actuator is located so you know where to drill the mounting holes. Mount the actuator (I think you can mount it anywhere, but I am not 100% sure) and give it a go. PM me if you are still intersted. The price is flexible if you are still considering this with no install instructions. Just shoot me a PM with your offer. Thanks.
Old Jan 7, 2008 | 07:27 AM
2da mizzax's Avatar
Actuator has to be mounted in a specific position on the drivers side of the trunk right behind the gas door. problem is, right where the holes are to mount the actuator(they are already there), there is another box there (only in maximas). The same box is located elsewhere in the I30. If you mount the actuator anywhere else, it my not reach the gas door unless you do some careful measuring and drilling (Keep in mind the angle the door latch faces and which way the actuator must pull). I forget what the box is for, but it is in use. you can do 1 of 2 things. 1, take down the box and leave it hanging (just wrap it up or you will hear a ton of knocking) or 2, try to mount them together (which I did but didnt finish teh install since i broke the plastic door latch ) then run the wires to the front of the car and run a + to one end of the switch, other terminal of the switch to the + on the actuator, and you can simply chassis ground the - of the actuator. not hard, but a pain in the ***.
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
