FS: RMT Turbo kit - SAFC NEO - NGK AFX Wideband - Walbro ect
Old Apr 24, 2008 | 07:31 PM
shortyblu95's Avatar
**edit i went ahead and took the liberty of powder coating the IC piping and im keeping the price the same til the end of the week or so.**
SOLD!!!!!!!!
I am loosing money on this stuff big time as you should know. So if your even remotely thinking about going rmt this is one h*ll of a deal. Shoot me a pm if intrested
**EDIT Just turbo itself sold the rest is still available as a kit
Alright ive gotten a great offer to buy a car ive always wanted from a friend so im going to be watering down the maxima and keeping it as a daily driver...
First up for sale is a ALMOST complete remote mount turbo setup (RMT). I know you’ve all seen streetz, 95blkmax, and a few others with there remote mount turbo setups. Here’s your chance to take out all the guess work with lengths, fittings ect and buy this setup as a kit from me. The kit could be sold as several different options depending on what someone is looking for/ looking to spend ect. Things I have are:
Turbo
(Just Turbo itself is no longer included in the kit)
- JoeP Manual boost controller
Oil feed and return
--4AN stainless steel feed line (120" length)
--10AN Turbo to Pump and pump to Valve cover (18 feet)
-Glowshift oil filter sandwich plate for oil feed (4- 1/8" NPT ports)
- 1 1/8NPT ->-4AN adapter for oil feed fitting
- 1 oil feed fitting for turbo -> -4AN
- Return fitting on turbo for -10AN hose
- Shurflo 8000-643-236 "scavange pump"
- 3/8"NPT -> -10AN fittings for oil return to scavenge pump
- -10AN weld on fitting for valve cover (can also just thread it through a drilled hole and silicone to prevent leaks if cannot weld or find welder to do it
- -10AN 90* fitting for valve cover so the line comes out correctly and you don’t have to mess with any clearance issues
- Many correctly sized stainless rubber coated support clamps to hold up the feed and return lines to the underbody of the car with self taping screws so you don’t have to deal with ziptieing lines up or sagging issues between mounting points
Intercooler, Piping, BOV
- 24x12x3 Large FMIC core fills bumper perfectly (31" total length with end tanks)
- Mounting bolts, washers, hardware for intercooler
- Complete cold side piping from intercooler outlet to throttle body that enters in place of washer fluid reservoir
- All pipes have beaded ends to prevent blowing off
- Flanged for 1g DSM blow off valve
- 1g dsm bov
- All couplers and clamps included
- 4" long intake pipe with filter
Fuel
- Walbro 255HP fuel pump (GSS342)
- Almost every part listed is brand new except the bov, which is in like new condition.
- The intercooler was mounted, as seen in pics. This was done to fit the piping to it but no air has ever gone through it, and when not being worked on the end caps were always on it to prevent debris from entering.
Looking to get $500 shippedfor the kit as a whole. Im going to be keeping the safc and wideband that were listed earlier. The only things you would need to buy to complete the kit is a 7.5ft pipe for the hotside car length sense im not shipping that, injectors or an FMU, and weld the included inlet flange on to your catback (+hangers). This is by far the most complete kit as far as # of different items that come with the kit instead of the main things. Like I stated above, it really takes the guess work/headache out of fittings, hose length, finding components that fit and work together ect. Im not going to be intrested in parting anything out.
I’m going to post a bunch of pictures of the stuff although my camera batt died before I could finish, so I will be adding more tomorrow of anything you don’t see today.
Old Apr 24, 2008 | 07:32 PM
Old Apr 24, 2008 | 10:55 PM
supermanrox305's Avatar
Well you part out just the Apexi Neo ? If so pm me.
Old Apr 25, 2008 | 07:47 AM
*bump price change*
Im going to be keeping the SAFC and wideband. Full kit price is now $1200 shipped obo
Old Apr 25, 2008 | 08:43 AM
deezo's Avatar
You guys know the rules. If you're not interested, keep on moving and stop spamming.
Old Apr 25, 2008 | 09:54 AM
tsaulz's Avatar
What size oil restrictor would I need for the turbo?
Old Apr 25, 2008 | 09:57 AM
The oil feed inlet fitting i got is specific to these garrett turbos and has a restrictor already built into it to be used with the -4AN line also included.
Old Apr 25, 2008 | 11:18 AM
ajcool2's Avatar
Man this is tempting. If I wasnt going on vacation next month I'd buy this right now.
Old Apr 25, 2008 | 11:55 AM
t6378tp's Avatar
Turbo 3.5
does anyone else but me think a t25 is alittle small for a maxima. Doc used a t28 and only made around 220whp at 10psi
not trying to bash your thread but how much for this kit without the turbo encase someone else was thinking the samething
Old Apr 25, 2008 | 12:38 PM
I know what you mean, it is a bit small for the application in theory but i figured that would help some being utilized in a rear mounted setup. I just wanted to have power right off the bat sense i am running a MEVI i wanted it to hit hard in the midrange and let the MEVI still make power up top too.
If someone really wanted the kit without the turbo, & the inlet flange for it i could do $900 shipped. I just really didnt want to split it up and the price i have it up for imo is already good for everything thats included.
Also took a pic of the oil feed line sense i didnt have one up before...
Old Apr 26, 2008 | 07:41 AM
all pm's replied!! sounds cheesy but Nowhere else are you going to find this complete of a kit for this price
Old Apr 27, 2008 | 07:54 AM
bump ttt
Old Apr 29, 2008 | 06:17 AM
bump ttt
Old May 2, 2008 | 06:13 AM
BUMP new price... $825 shipped!!
Old May 2, 2008 | 08:22 AM
maxima92se's Avatar
Bump for you good price!! If i wasnt FI i would be all over this kit. If you ever wnat to part it out keep me in mind for the FMIC and most of the piping and clamps. Thanks and good luck.
Old May 2, 2008 | 03:05 PM
Product_Of_Korea's Avatar
omg the pain!
Old May 3, 2008 | 10:24 AM
lol just in time for stimulas payments!!
Old May 3, 2008 | 11:22 AM
eh i already have it spent i did all my mods with the federal taxes
Old May 4, 2008 | 05:57 PM
all pms replied
Old May 4, 2008 | 08:05 PM
Just incase anyone intrested doesnt have the full amount, i am willing to accept half payment now half later (when you get paid or something) because i relize this is alot of money to spend all at once.
Old May 4, 2008 | 10:59 PM
93altima's Avatar
Turbo 4th Gen
i have 600 on me right now the turbo isnt included???
Old May 5, 2008 | 11:39 AM
pm sent, also correct the actual turbo itself is no longer included which justifys the lower price
Old May 6, 2008 | 07:14 AM
updated
Old May 7, 2008 | 09:26 AM
daily bump
Old May 8, 2008 | 08:52 AM
i went ahead and took the liberty of powder coating the IC piping and im keeping the price the same til the end of the week or so. Heres a picture of same TB pipe pictured before but now powder coated..
Old May 8, 2008 | 05:32 PM
thursday night bump
Old May 8, 2008 | 11:03 PM
kzoosho's Avatar
so you have all the exhaust as well or would i need to modify that ? Let me know i may be interested at 600 man.
Old May 8, 2008 | 11:10 PM
pm sent
Old May 9, 2008 | 08:50 AM
bump ttt
Old May 10, 2008 | 08:34 PM
weekend bump!
Old May 11, 2008 | 12:17 PM
price bump i NEED this gone ASAP!
Old May 12, 2008 | 06:26 PM
Alright guys this is it.... I changed the price to $500 shipped FOR EVERYTHING, which is absolute bottom dollar and im loosing hundreds (literally). But i really need to sell it and get ahead right now money wise more than i need this kit.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
