FS:00VI Setup
FS:00VI Setup
Yes thats right I have another one for sale. I feel like a 00VI dealer now lol. The kit consists of the following:
2000 UIM (slightly damaged in the rear)
LIM
Fuel rail
Injectors
Rear valve cover
3 coil packs
The nipple on the rear of the UIM is melted and needs to be tapped with a new nipple. This isnt exactly a bad thing if your going to be running the 4th gen IACV because it will need to be tapped anyway if you dont want the cold start issue. I DO have the 5th gen TB and IACV but they are not for sale just yet. I'll let everything go for $350 shipped.
LIM
Fuel rail
Injectors
Rear valve cover
3 coil packs
A can of air intake cleaner should do the trick. I actually sprayed the top of the manifold just to see what would happen and the dirt came right off without any wiping. You'll need adapter plates for you 4th gen throttle body and IACV or a 5th gen throttle body and IACV. You'll also need a blockoff plate for your EGR or an EGR guide tube. I made my block off plate out of sheet metal. I'm pretty sure that it. Also it does come with all injector clips in case anyone was wondering.
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
