F/S Valve Cover Gasket Set
Old Mar 22, 2010 | 07:52 PM
BORQUA79's Avatar
nycmaximas member
This is for you guys with leaking gaskets or worn o-ring spark plug rings. Replacing Gaskets can help with loss of compression=more power!!!
complete set of front and rear valve cover gaskets(2). Comes with spark plug grommets (6) and screw grommets(10). All brand new bought an extra set by mistake and opened to make sure all pieces were there. For you guys near NYC Location is Brooklyn NY. Asking $40 picked up $45 shipped
Last edited by BORQUA79; Apr 25, 2010 at 09:46 PM. Reason: lower price...by $10 dollars
Old Mar 23, 2010 | 08:32 PM
BORQUA79's Avatar
nycmaximas member
bump...
Old Mar 23, 2010 | 09:45 PM
mista0406's Avatar
bump for a great part
GL
Old Apr 4, 2010 | 03:44 PM
BORQUA79's Avatar
nycmaximas member
bump it up!!!
Old Apr 11, 2010 | 06:23 PM
BORQUA79's Avatar
nycmaximas member
bump again...
Old Apr 25, 2010 | 09:45 PM
BORQUA79's Avatar
nycmaximas member
anyone need gaskets???
Old Apr 25, 2010 | 09:47 PM
BORQUA79's Avatar
nycmaximas member
lower price take a look...
Old May 16, 2010 | 08:38 PM
FallenOne's Avatar
Hey man, give me a rain check but im most likely going to be taking this off your hands soon.
Old Jun 12, 2010 | 02:32 PM
bullet187's Avatar
I am having trouble removing the spark plug gaskets... Is there any trick to removing them? I tried to remove one and it ripped off. Need help ASAP...
Old Jun 12, 2010 | 02:42 PM
Sproket13's Avatar
I need me a set of these. is that the Fel-pro?
Old Jun 13, 2010 | 02:16 PM
BORQUA79's Avatar
nycmaximas member
I used a hooked screw driver to pry it off. It's tough... I was desperate that I used a dremel and cut notches in the rubber. It has a metal core in each of the rings. Be careful not to damage the cover.
Old Jun 15, 2010 | 10:19 AM
BORQUA79's Avatar
nycmaximas member
Lock it up... Everything sold!! Thanks
mvm062
Nov 30, 2020 09:00 AM
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
03VQMAX
Sep 5, 2015 03:47 PM
