00VI, VAFCII, valve cover, SC pulley, 98 a/c compressor, pushout tray, shifter trim
Old Sep 15, 2010 | 09:20 AM
HomerMAC's Avatar
Donating i30 Owner
THINGS IM SELLING. These parts are all sold as is. You might have to custom fit things and is being sold under the assumption that you know what your buying and thats that.....
PM ME PLEASE
OBO for some items accepted.. but VI for $220 is pretty good I think....
1. 00VI $220
just taken out of my DEK a week ago. notice the fuel coming out of the rail in the pic. (for proof of fresh-ness)
(comes with upper/lower IM, TB/iacv [with wiring pigtail for 4thgen to make this simple splice and play], Injector rail/injectors, coil packs, used metal gaskets, EGR block plate, Intake Assembly as shown in pic & custom midpipe & k&N drop in filter with recharging cleaner/solution)
This setup will fit perfect for any 4thgen. it even keeps the stock intake setup.
You should service the injectors before installing (meaning new caps/o-rings) I mean you have it out, why not clean the TB etc.
You have to get a rear valve cover for DEK. there is another member on
here mitesh (please text him, phone# with his permission : 516-303-2571) selling the valve cover with the gasket for $50(I think, pretty sure of the cost)
Also you can get the VAFCII with the OOVI for $70 if you buy it all together.
2.VAFC II SOLD
its a air fuel controller, comes with harness to connect to ECU+ harness to connect the vafcII to the ECU harness. NO MOUNTING STAND
3. 5spd shifter trim $10
cig lighter holder broken off. I have successfully repaired one before and can tell you how to do this one as well.
4. WOODGRAIN pushout tray $25 (got it from dealer about a year ago, has a slight scuff but def. shiny and looks NEW)
5. Flip out tray $10
6. Intake filter $20 (BRAND NEW)
with coupler, clamps, support piece to mount to strut tower
7. Mass Air Flow sensor (vq30de) $45
I have two available
8. 2.87" SC pulley $25 (im selling it cheap because it has a mark from something hitting it going across all 6 ribs. It was used and working fine for a year before taken off car. http://i967.photobucket.com/albums/a...2/DSCN2330.jpg <<-- shows the mark. It is hair sized. look at it)
9. Clarion 6CD changer $45
Add a 6cd changer to the bose system. It comes with a harness that connects to the back of the radio and is long enough to mount the cd changer in the arm rest (i had it here) or under pas/driver seat.
10. TAN auto dim mirror WITH a red security LED $35
The red led gives a BMW like blinking from the mirror and can be seen from far away through windshield
11. VQ30dek mid piece for the intake $20
12. IACV $25
13. vq30de throttle body Without TPS sensor $10
14. 98 AC COMPRESSOR $75
working pulled from crashed car
15. VQ30DET FUEL RAIL w vq30de injectors $40
I always rec. getting new o-rings and servicing any injectors before install cause its a PITA to do again.
16. vq30de rear Valve cover $25 painted RED
I spend a lot of time on this. When you see the thick coat and shine you can tell it was painted over the coarse of several coats and heated to seal in that glassy shine.
CLICK HERE!!!! ---->>> HUGE PICS in this PHOTOBUCKET ALBUM.
pick up preferred in QUEENS by the cross island parkway or clear view park way.
will ship if shipping is paid for using USPS. only charged for actual shipping which will be a label on the shipping box from NY
Old Sep 15, 2010 | 01:43 PM
Any pics of that rear valve cover installed? I'm interested in the auto dim mirror as well. How much picked up for both?
Old Sep 16, 2010 | 05:36 AM
06_touring's Avatar
Originally Posted by HomerMAC
please call,txt me. THANKS. DONT PM ME... if you dont have a phone.. you shouldn't be wasting money on car parts... save up for a phone. not to be a ***** but I dont come on nyc.org often enough.
PM ME PLEASE
First you say don't PM then you say PM me please...which one is it? Also how do we txt if you didn't provide a number?
Old Sep 16, 2010 | 02:57 PM
silencecalls's Avatar
PM about shipping sent. Thanks =)
t6378tp
Sep 29, 2018 04:27 PM
tgreen
Oct 18, 2015 06:18 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
