WA FS: Shortened Konis on H&Rs, Wilwood 12.2" brake kit
Old Nov 14, 2012 | 01:24 PM
hurddawg's Avatar
Hello
I have decided to reduce my vehicles and my Maxima is one of them on the list. So here are some parts that I have taken off as I start returning to stock.
Up for sale are already modified, just bolt up and go set of Koni adjustables with H&R springs. I have the H&R rear springs on the upper perch of the shock body, so you will not have the saggy rear end syndrome.
Front and rear have been shortened as pictured. The rear have been shortened by the use of aftermarket rear shock mounts for a P11 G20 I bought on G20.net. Almost all parts are new, including new bellows. If I remember correctly, I have also shortened the bump stops a bit. I have the Front/Rear adjusted in the middle, 2.5 turns on the front and 2 turns on the rear.
One problem...One rear shock mount has a damaged stud
(in pic). I've tried to "repair" by running a tap on it, but it isnt perfect. I've driven it like this without any knocking or odd noises.
This is a great riding set up with a modest drop! I spent a lot of time researching and getting these put together. I've only driven about 1500 miles on this, so they are basically new.
(Updated Pricing, 2/14)
Looking for $650 shipped to the lower 48 for the set.
Wilwood 12.2" brakes. This was put together by Brian at Fast Brakes. The pads are Hawks. The kit will include all hardware necessary to installation. This also was used only for 1500 miles. They were installed at the same time as the Konis.
They are made to fit 16" wheels radially. With 17x7.5 CE28Ns, I needed +33 to clear the calipers as the calipers are huge.
Updated
Looking for $650 shipped to the lower 48.
All as basically new parts, just bolt in and go. I did all the hard parts
Pics - Wilwood
http://i265.photobucket.com/albums/i...Kit/Rotors.jpg
http://i265.photobucket.com/albums/i...pads-rotor.jpg
http://i265.photobucket.com/albums/i...it/Caliper.jpg
Pics - Koni
http://i265.photobucket.com/albums/i...ifiedKonis.jpg
http://i265.photobucket.com/albums/i.../KoniLabel.jpg
http://i265.photobucket.com/albums/i...is/HRLabel.jpg
http://i265.photobucket.com/albums/i...Konifronts.jpg
http://i265.photobucket.com/albums/i.../StrutTops.jpg
Old Nov 14, 2012 | 03:07 PM
SpeedCrazie's Avatar
Sorry to see you go!!
Old Nov 20, 2012 | 08:29 PM
hurddawg's Avatar
Bump
New pricing on Suspension set up
Old Dec 6, 2012 | 10:41 AM
hurddawg's Avatar
Ttt
Old Dec 6, 2012 | 10:47 AM
Quickywd01's Avatar
I have those brakes, sexy. GLWS
Old Dec 7, 2012 | 10:38 AM
hurddawg's Avatar
Updated pricing on brake kit. They are out of production now...I had Brian "custom make" this set.
Old Dec 7, 2012 | 11:52 AM
MAXIMA_STYLE's Avatar
Glws but just an fyi.. most people use oem bbk setups... i sold my wilwood 12.6" setup for 450ish shipped...mine wasnt as clean but its hard to resell a wilwood kit consiering most people use oem bbks now...
Old Dec 7, 2012 | 03:48 PM
hurddawg's Avatar
Well taking that in consideration, I'll adjust the price a little bit more. But these are way more kick *** than the heavy oem style ones.
Old Feb 14, 2013 | 11:10 PM
hurddawg's Avatar
Updated pricing
Old Feb 17, 2013 | 08:30 AM
kasso28's Avatar
where can you get the rotors for when they need to be replaced?
Old Feb 17, 2013 | 11:32 AM
hurddawg's Avatar
You can get the rotors from fastbrakes.com for one. From info I got from fastbrakes, anyone that carries wilwood 2 piece rotors in this size (12.19") will have the replacement rotor.
Old Feb 17, 2013 | 06:07 PM
jac121479's Avatar
very clean suspension setup. i'll give it some thought.
Old Feb 17, 2013 | 07:56 PM
jac121479's Avatar
Are the studs pressed into the rear mounts or are they just slide in place bolts?
Old Feb 19, 2013 | 08:46 AM
hurddawg's Avatar
I believe they are tacked on. I'd have to look, but I am sure they at least pressed in as I would have changed the bolt out other wise. But in retrospect I should have just ground off the tack weld and put a new one on.
Old Feb 19, 2013 | 08:47 AM
hurddawg's Avatar
Sale is pending on both items.
Old Feb 19, 2013 | 05:58 PM
hurddawg's Avatar
Sold!
Old Mar 1, 2013 | 07:48 AM
jac121479's Avatar
did both sell?
Old Mar 1, 2013 | 10:58 AM
JasonGXE's Avatar
Yes I will be busy installing this weekend.
Old Mar 1, 2013 | 12:21 PM
hurddawg's Avatar
did both sell?
Sure did!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
