CT FS: 00VI kit and pathfinder throttle body
Up for sale is a 00VI kit which consists of a modified 4th gen lower manifold so you can use your stock 4th gen injectors. 00 rear valve cover with 00 rear coils. I have the upper 00VI with power valve removed and block off plate on it but it's painted and when I was porting the neck to match the pathfinder throttle body I put a hole in it then patched it with RTV liquid gasket but it should be fine. Also have a pathfinder throttle body and a adapter but the adapter is jacked up a little as I tried to modify it for the pathfinder throttle body. Also a IAC adapter plate. Also comes with egr guide tube. Price for all is $425 shipped in the USA serious buyers only thanks. Note this is a plug n play kit for people who don't like to wire up injector harnesses and don't like wiring up the vacuum switch and also comes with bolts
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
