NM FS - 00vi (4th gen tb/lim setup), garage clean out
Old Jul 22, 2017 | 02:41 PM
soseihin's Avatar
Greetings! I sold my car so now I have a bunch of maxima parts I can't do anything with.
Here's a list:
- 00vi setup:
4th gen lower (flipped and drilled to fit, should probably be professionally redone), 4th gen TB adapter and IACV adapter from Stephen Max, summit switch, upper has already been tapped for vacuum lines. Still needs rear valve cover modded to fit. I believe it's otherwise complete. Comes with everything pictured above. Hardware included. Selling as a complete set. $200 + shipping
- Ignition switch (I believe it's the OEM switch). $10 + shipping
- Clutch start switch (OEM) $10 + shipping
- Old style K-sports: Front inserts are blown, rears I believe are still good but no guarantees. By "old style" I mean these are no longer being made. If you're interested in these with the intention of contacting K-sport to replace the blown inserts, you'll need to buy all new hardware from them which I believe I was quoted is about $200/corner $50 + shipping
- Factory 15" steelies and hubcaps w/ mounted Yokohamas that still have some life. $50 pick up only
More pictures available here: https://maxima.org/g/album/7698880
Not in picture:
- Stock exhaust manifolds, y-pipe & heat shields - $25 pick up only
- Raxles half shafts boots are torn, CVs are good but should probably be rebuilt anyway. (Non-LSD, non-ABS, manual transmission) $25 each + shipping
Pics available on request.
All prices are firm and do not include shipping.
Last edited by soseihin; Jul 27, 2017 at 01:47 PM. Reason: Added more info about the K-sport
Old Jul 24, 2017 | 01:53 PM
chongher's Avatar
U got pm
Old Jul 25, 2017 | 11:29 PM
MaxiMike's Avatar
Pm sent!
Old Jul 26, 2017 | 10:49 AM
soseihin's Avatar
All PMs answered, pictures of the Raxles added to the album per request: https://maxima.org/g/album/7698880
Old Jul 27, 2017 | 01:16 PM
SeniorCitizen95's Avatar
ksport coilovers
how much for coilovers shipped to 10965?
Old Jul 27, 2017 | 01:44 PM
soseihin's Avatar
Got a couple of people already in line for these, but it'd be about $50 using FedEx ground shipping to 10965, so $100 total.
I should probably iterate that these are the old style Ksports and specify that they're no longer being made. If you're interested in these with the intention of replacing the blown inserts you'll need to buy all new hardware which I believe is about $200/corner.
... actually I'm going to add that to the description.
