TX WTB Plate-Air Guide (DS radiator shroud)
Old May 6, 2019 | 11:56 AM
reallywildstuff's Avatar
For 1998 i30
This part wasn't there the last time I took the fans out - don't know what happened to it. This is a rectangular piece of black plastic on driver's side ("L" stamped on it) at the front of the car - it slips onto the fan assembly. There's a similar piece (but not the exact same) on the passenger's side (R) as well.
https://www.infinitipartsdeal.com/Pa...3&PartNumbers=
Lookup Code 21494+A, Nissan P/N 21494-31U10
I'm also still looking for a cup holder clip:
https://maxima.org/forums/4th-genera...lder-clip.html
Old May 7, 2019 | 04:41 PM
MaxDiddy's Avatar
Plate air guide
Hello, Sorry car had lower front hit and all the radiators and fan conponents were destroyed and subsequently disgaurded. I will check about the cup holder clip when I can and let you know.
Jim
Old Oct 27, 2019 | 07:35 PM
I bought a factory shroud from a forum member.
the first pic is the factory shroud next to my AFTERMARKET dryer and condensor. The shroud doesnt slide into pace on the factoey radiator attach points because the condensor/dryer line interferes (has differnet physical dimensions).
the next pic is how I cut the factory shroud to fit the aftermarket plumbing
Next is the final trim job, with rounded hole for final line location
Final pic is trimmed factory shroud mounted on factory radiator mount points and clear of aftermarket ac plumbing
ADHDmax
Oct 17, 2011 05:25 PM
mtrai760
Oct 23, 2008 02:33 PM
Tato97SE
Dec 3, 2007 05:26 PM
